Buying LT133 Later Today
3 replies to this topic
#1 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted April 12, 2015 - 07:38 AM
Hey guys, I am going to look at /buy a LT133 later today.  i think it is 2002 - 2005.  It was purchased at a JD dealership. I think it is a manual trans.  It looks great in the pictures.  The only thing bad is the deck has "worn through" in the corner due to mowing a sandy lawn area - the previous owner thinks it sandblasted through.  I will take a look and see if rust played a role in it or what.... anyways...
What common problems should i look for?
How does the PTO work? Electric? If the deck is not installed how can i test it?
i'll send pics later -    300 bucks a good deal if it's in great condition and i have to patch deck???
also - anyone patched a deck before?  cut out old piece and mig in a new one?
Edited by fxdb96, April 12, 2015 - 07:55 AM.
#2 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,213 Thanks
  • 2,951 posts
Posted April 12, 2015 - 11:01 AM
type in john deere LT133 in a search engine and then go see what tractor data tells you about the mower, including the years they made it.  that mower deck is a  problem tho...if the deck is not attached you might want to go ahead and attach it to make sure you have all the parts....there is a lot of parts on epay for a LT133...  I once welded a patch on a mower deck for a john deere 140..  had to be careful about burning thru the deck.  I used some galvanized sheet metal I picked up at a hardware store and bent/formed it to fit the shape of the deck where I was patching.  I did the welding outside and stood upwind when I was welding...I used a stick welder set at 35a. I think, with 1/16 rod.  worked out fine.  I would guess the deck on the 1972 john deere 140 was a bit thicker that the 38 inch deck on that 133 tho...
Edited by Delmar, April 12, 2015 - 11:04 AM.
  • Alc and propane1 have said thanks
#3 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted April 12, 2015 - 05:08 PM
Got her home. Looks good so far! Works real nice. More pics to come
  • Gabriel said thank you
#4 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted April 12, 2015 - 05:44 PM
Here are some pics of the deck. Previous owner said his lawn was extremely sandy.
