old pulleys been sittin outside
12 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 11, 2015 - 08:13 PM
is there a trick for cleaning up and lubing up old pulleys ? maybe hose em with some wd and push grease into em ? I just know the brilliant minds here have way better solutions than me
Edited by alec, April 11, 2015 - 08:13 PM.
  • hamman said thank you
#2 classic ONLINE
classic
  • 5,620 Thanks
  • 2,345 posts
Posted April 11, 2015 - 08:30 PM
Water is the worst thing for idler pulleys, and any roller bearing for that matter. The balls or rollers get rusty and there is no real fix for them. A freed up water damaged idler will get noisy and loose in a short amount of run time. Sometimes, old dried grease can be flushed out with gas or WD as you mentioned. You should be able to push some grease in the bearing afterwards.
  • hamman, superaben and alec have said thanks
#3 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 11, 2015 - 08:38 PM
well well well classic to the rescue ! I was hoping for some magic trick like soaking it in bacon greese or something ....  HEY !! at least it would smell good as it squeeled HA !  oink oink
  • hamman, KennyP, KC9KAS and 2 others have said thanks
#4 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,597 Thanks
  • 2,908 posts
Posted April 11, 2015 - 08:48 PM
My BIL has a needle fitting for his grease gun, he just drills a small hole in the rubber around the bearing and fills it with grease. Seems to work good for him. He took a Simplicity tiller that had been sitting outside for 15 years and made the mule drive pulleys work like new.   Good luck.                                 Roger
  • Gtractor, LilysDad, classic and 1 other said thanks
#5 Cvans ONLINE
  • 7,278 Thanks
  • 6,369 posts
Posted April 11, 2015 - 09:03 PM
I use a syringe filled with grease. Slip the needle under the lip of the seal and add the grease. A larger diameter needle makes it easier depress the plunger.
  • Gtractor, hamman, classic and 1 other said thanks
#6 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 11, 2015 - 09:30 PM
I use a syringe, too.  That way I can grease the bearing any time I need to.
  • hamman and alec have said thanks
#7 MH81 OFFLINE
  • 29,978 Thanks
Posted April 11, 2015 - 10:30 PM
Many idlers are held together with rivets. The bearings inside are often common ones and then you can bolt or possibly rivet the idler back together.
If its a common one, many idlers are available. Bolens1000 has a number of them, I'm sure SuperABen does too, probably most of our Sponsors would or could
  • KennyP and alec have said thanks
#8 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 11, 2015 - 10:33 PM
oh yeah !!! thats what I am talking about ! I even have a big syringe from the ear doc . thanks guys !!!
#9 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 11, 2015 - 10:35 PM
ha ! that explains one that I have thats held together with nuts and bolts !
#10 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted April 11, 2015 - 10:58 PM
I have pried the rubber seal off (with a jewelers screwdriver) and used carb cleaner to free the bearing up, add some grease and push the seal back on. Only works on the older ones that you can remove the seal.
Edited by larrybl, April 11, 2015 - 10:59 PM.
  • Cvans and alec have said thanks
#11 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 12, 2015 - 08:07 AM
For several yrs I've been carefully removing the crimp over the outer race w/ a burr bit in my die grinder, knock the old out and coat the bore and new brg w/ locktite. Haven't had one come loose yet.
Mike
  • alec said thank you
#12 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 12, 2015 - 10:36 AM
Mike
so you buy a new bearing ?
#13 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 12, 2015 - 08:29 PM
Yep, most bearing sales stores will have them on the shelf. If you can't find the numbers take the old inner and outer races there and they'll find the replacement w/ inner and outer diameters.
Mike
