Can coil and points be added to 422400 opposed Briggs?
38 replies to this topic
#16 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 11, 2015 - 10:25 PM
Compression tested great last year or so ago, and I haven't messed with it since it last failed to start last year.... But still no kick with the starter fluid I hate using.
I haven't used starter fluid in years..my friend tells me its not the same as it was back when I last used the stuff...did they change it?
#17 Jlaws OFFLINE
Jlaws
  • 548 Thanks
  • 367 posts
Posted April 11, 2015 - 10:26 PM
Gopher , the opposed twin briggs has only one twin lead magneto to fire both plugs and it does have points to fire the mag . At least the cub cadet opposed twins do....
Casey , the first thing I would check is the shearkey on the flywheel , I've seen occasions where they are sheared about halfway thru and they will give a weak spark
Edited by Jlaws, April 11, 2015 - 10:27 PM.
  • gopher and Auburn David have said thanks
#18 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted April 11, 2015 - 10:28 PM
Been there and checked that flywheel key. I have been all under that shroud and flywheel and no points exist that I ever saw.
#19 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,010 Thanks
  • 5,462 posts
Posted April 11, 2015 - 10:29 PM
http://www.m-and-d.c...ms9492-0102.pdf
#20 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted April 11, 2015 - 10:34 PM
Been there twice today Doug.
#21 Jlaws OFFLINE
Jlaws
  • 548 Thanks
  • 367 posts
Posted April 11, 2015 - 10:47 PM
Now I'm going by my 582 cub cadet opposed twins ......if it has points like the cubs they will be on top of the engine between the carb and flywheel . They are easy to miss. you almost have to take the carb off to get the points cover off
Edited by Jlaws, April 11, 2015 - 10:49 PM.
  • wvbuzzmaster said thank you
#22 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,010 Thanks
  • 5,462 posts
Posted April 11, 2015 - 11:02 PM
Looks like there's 2 different styles of Magnetron coils used
Composite style armature
Armature with Magnetron module
Which one you have?
http://www.globalsof... & STRATTON.pdf
#23 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Just went out there, did not see it, but did grab the shroud off the starter side (already off and has the numbers)
422437 1209 01 88012812
I have a parts engine
422437 1266 01 90030812
Edited by wvbuzzmaster, April 11, 2015 - 11:04 PM.
  • Auburn David said thank you
#24 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Which one you have?
I'm pretty certain Magnetron.
#25 Jlaws OFFLINE
Jlaws
  • 548 Thanks
  • 367 posts
Posted April 11, 2015 - 11:14 PM
Ok , you got me wondering about the points on a opposed twin , so I walked out to the garage to check the three opposed twin blocks that I have sitting on the shelf . Two of the three have the points setup , but one that I have and evidently isn't a cub engine doesn't have the points provision . So I guess there was a change sometime during their production , making my previous posts about points  pretty much moot .
Edited by Jlaws, April 11, 2015 - 11:15 PM.
#26 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted April 11, 2015 - 11:20 PM
Can you take a picture of these points setup. Even if it doesn't help me convert mine it might help someone else looking for them.
#27 Jlaws OFFLINE
Jlaws
  • 548 Thanks
  • 367 posts
Posted April 11, 2015 - 11:57 PM
Here's a couple of pictures of Briggs opposed twin engine blocks  with and without points provision .
Edited by Jlaws, April 12, 2015 - 12:32 AM.
#28 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted April 12, 2015 - 12:25 AM
Right next to the vacuum line?
#29 Jlaws OFFLINE
Jlaws
  • 548 Thanks
  • 367 posts
Posted April 12, 2015 - 12:34 AM
Yes , its next to the vacuum line . Its a lot harder to see with the flywheel and flywheel shroud installed .
#30 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted April 12, 2015 - 12:37 AM
Ok, just walked out there and definitely don't have that points cover on the one I am messing with, but I have a earlier GTV 18 I was given for free that is sporting one of those covers, and I may be taking a close look at it for either using all the sheet metal from the parts GT 18 machine to make it run and drive.... Hmmm... Or might need its engine for the Caterpillar... Lol.
Ps, the gtv18 I got free was advertised as needs gas tank, and I would say fender pan, seat, and the hood to open, as well as steering work lol.
Edited by wvbuzzmaster, April 12, 2015 - 12:39 AM.
