318 hydro fluid level
1 reply to this topic
#1 Jeepguy OFFLINE
Jeepguy
  • 6 Thanks
  • 4 posts
Posted April 11, 2015 - 12:32 PM
When I try to add hydro fluid it doesnt go down th fill tube,it is very slow is there a plug I need to remove to add fluid.
  • larisaPn said thank you
#2 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted April 11, 2015 - 05:59 PM
Don't recall it being much different then tran fluid in car look to see if fill tube kinked. You could jack up rear and turn wheel in gear use a small funnel long spout and fill up the funnel. Not sure if it has to be in gear to get fluid moving around when turning wheel. All the green must be out working the gardens sure one of them with more insight of these tractors tell you what the problem might be.
