On my way home
14 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted April 11, 2015 - 10:58 AM
Loaded up and heading home now
  • tinbender7 and T Guiles have said thanks
#2 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted April 11, 2015 - 11:00 AM
Forgot to add pics
  • Gtractor, LPBolens, Alc and 4 others have said thanks
#3 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted April 11, 2015 - 11:11 AM
Looks good. Have fun trying them out.
  • tinbender7 and bbuckler have said thanks
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 11, 2015 - 11:22 AM
As Napolean Dynamite would say,     LUCKY
  • tinbender7 said thank you
#5 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted April 11, 2015 - 11:53 AM
These are Sears 3 point will they work with anything other then Sears
  • KennyP and tinbender7 have said thanks
#6 KennyP ONLINE
  • 40,901 Thanks
  • 47,100 posts
Posted April 11, 2015 - 01:55 PM
Nope! Sears 3-point is a narrow configuration. Normal Cat 0 width is 20". Sears is like 12".
  • tinbender7 and boyscout862 have said thanks
#7 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted April 11, 2015 - 02:01 PM
after 4 hours being on the road and $300 there has to be a way to make it fit
#8 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted April 11, 2015 - 02:09 PM
just go buy a Sears tractor
  • oldedeeres said thank you
#9 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted April 11, 2015 - 02:10 PM
Can't find one around here
#10 KennyP ONLINE
  • 40,901 Thanks
  • 47,100 posts
Posted April 11, 2015 - 02:34 PM
Yes, just put extensions on the pins out to what you need.
#11 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted April 11, 2015 - 02:38 PM
Sits higher then the cub cadet 3 point
#12 KennyP ONLINE
  • 40,901 Thanks
  • 47,100 posts
Posted April 11, 2015 - 03:02 PM
They do? Never had a Sears 3-point implement. But, I'm sure I could find a way to use them without destroying the original configuration.
#13 Freddie1911 OFFLINE
Freddie1911
  • 149 Thanks
  • 98 posts
Posted April 11, 2015 - 04:17 PM
 If your lift arms have offsets like the massey, swap sides with the arms.   Freddie
#14 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted April 11, 2015 - 08:28 PM
I have a idea that might work it going involve angle iron.
#15 markus OFFLINE
markus
  • 14 Thanks
  • 18 posts
Posted April 14, 2015 - 03:21 PM
I found a set of Sears cat 0 attachments a few years back . A 10 inch moldboard plow , disc , cultivators , and snow plow . rust free and in very nice shape , with all the attachments and had to have them . I restored all to better than new condition with TLC , grease and most important , JD green paint job and last year I decided to use them on my small garden plot ( 1/4 acre ) but needed to figure out how to get them to work on my 2013 JD (e series) tractor . The distance between the pins on the Sears 0 cat implements is about 12 inches and the attachments for the top link is too low to hook up in any normal fashion so after a few restless nights and a few hours in the garage studying the problem I decided the simple solution to the problem was to get a three point draw bar for my "cat 1" hitch ( must have a stabilizing bar for the top link ) and attach the cat 0 implement to " it " using some HEAVY clamps . There are lots of ways to do this , if your a little bit handy you can figure it out . You can find a three point draw bar for a cat 0 or any hitch category tractor , cheap end would be Northern Tool or Eezs.com or USA made and very high quality , heavyhitch.com . These cat 0 implements were made around 1974 and are constructed quite well and work great for a small garden plot . Good luck
  • KennyP and bbuckler have said thanks
