102 oil leak
3 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,669 Thanks
  • 3,201 posts
Posted April 10, 2015 - 09:24 AM
I noticed yesterday it has a very slow leaking around the oil drain plug the plug is in there tight. Is there anything I can use on the plug to stop the leak ?
#2 M.Cain OFFLINE
M.Cain
  • 185 Thanks
  • 158 posts
Posted April 10, 2015 - 09:42 AM
I use Teflon thread tape on mine make sure the thread are clean and dry first works well. :thumbs:
Edited by M.Cain, April 10, 2015 - 09:47 AM.
  • bbuckler said thank you
#3 EricFromPa ONLINE
EricFromPa
  • 4,006 Thanks
  • 3,266 posts
Posted April 10, 2015 - 12:25 PM
Cut the old seal off of the drain plug and put in a new one.I bought a kit with a bunch of seals in it from Autozone a couple years ago for around $8.I used one of the plastic ones because of the rather rough casting of the pan and it worked very well.I did have to cut the inner plastic tabs out but it sealed it up really nice.
#4 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted April 11, 2015 - 09:10 AM
+1 on Teflon tape.
Also, most of these plugs are NPT thread, which is a tapered thread. It seals by wedging the two surfaces/threads together. A new plug may give you a better seal...
