Sold
1969 Ford 140 Hydro with attachments and spare engines
2 replies to this topic
#1 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted April 10, 2015 - 02:36 AM
$700
1969 Ford 140
14 horse Kohler
factory electronic ignition
electric start
Engine does smoke on start up but not bad
I cleaned and did gaskets/seals and painted the engine
New fuel pump
has working electric PTO
I have a 42 inch aluminum deck with a new belt to be installed
and blade could use a sharpening
38 inch single stage blower could use a little work and paint
but worked great
Have the sleeve hitch for it
I have the muffler shield
I also have the wiring and switch for an electric lift
lift was long gone when I got the tractor
I will include a weight box for it you supply the weight
I have a bracket for a plow blade you supply the blade
winch and bracket will go with the tractor bracket is mounted
under the grill assembly no holes were made in the grill
I have 2 spare core kohler 14 horse complete blocks
points motors rope start one has a busted rod
and missing fuel pump
other compression feels good have not tried to start
I have all factory manuals for tractor and attachments including parts lists
Now the bad but not so bad
missing the battery cover
missing the side screens
missing the link to raise the deck
hood needs to be painted I used rustoleum safety blue
the white on the seat pan needs to be redone runs(bad day for painting)
seat could stand a recovering
someone else was in the motor at one time or another
as the rod is scribed 010 and no balance gears
the funny bubble on the hood was a plastic butter bowl to keep snow out of the gas filler hole
has now been removed
The ag tires do not go with factory tires and rims are now back on
Sorry these are the only pics I have right now
as soon as I get current pics I will post them
  • KennyP, Sawdust and Thomasjent have said thanks
#2 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 366 Thanks
  • 500 posts
Posted November 14, 2015 - 11:05 AM
hi can I buy the deck off of you for my t120
#3 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted November 15, 2015 - 03:14 AM
Sold
Also tagged with one or more of these keywords: Sold
