Frankin tractor DUH moment.
20 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:20 PM
Well last week I tried out the FIL and Backhoe on Frankin tractor(ingersoll 6018) and they seemed REAL strong..to strong as a matter of fact..I blew a seal on the backhoe...anyway,today I air the tires up and check to see how she pulls...wont go at all in high gear..and just barely moves in low..my heart sunk..I came in and started looking over the parts manual and BING....I think I have the hydro clines hooked up backwards on the pump...I am not sure..but I sure hope thats what it is..that would explain the over strong cylinder blowing hydraulics and the no power right?
Edited by Auburn David, April 09, 2015 - 06:21 PM.
#2 boyscout862 OFFLINE
  • 12,535 Thanks
  • 9,034 posts
Posted April 09, 2015 - 06:26 PM
That is over my head. Just take your time and check everything. Lines should be setup with fittings so that they can't be connected wrong. Good Luck, Rick
  • Auburn David said thank you
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:28 PM
It has a dual stage pump..and I can hook either line to either port..
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:36 PM
These are the lines I think I have wrong..f388e80b-c408-4c56-80ba-a6ad834f040c_zps
#5 glgrumpy ONLINE
  • 8,555 Thanks
  • 7,878 posts
Posted April 09, 2015 - 06:37 PM
Sounds possible........Men don't read or need instructions you know!  Get the book out with diagrams, sheesh!
#6 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted April 09, 2015 - 06:38 PM
Do you have single or duel pump. If plumbed backward it would pressurize tank and low pressure lines big mess. Stuck relieve valve or just time for it to give out. Not moving might be air in system when filled  back up assuming loader on same circuit as drive or is it a stand alone system
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:41 PM
Wish I had a hydro diagram...
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:42 PM
Its a dual stage(2 pumps in one housing..one bigger than the other)
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:46 PM
Its not backwards...I think I have the feed lines mixed up..the big pump should be feeding the drive motor...
Edited by Auburn David, April 09, 2015 - 06:46 PM.
#10 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Your front goes to loader& backhoe back pump for drive & power steering.
#11 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:48 PM
I cant tell what line goes where..I am just hoping this is the problem.
#12 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 06:50 PM
It has a skid plate that covers everything..I need to take it off but it looks real heavy..LOL
#13 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted April 09, 2015 - 06:58 PM
I was wrong p steering on front to. Makes sense bigger line on front pumps 8.8 g /m  rear 4.8 g/m
#14 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 07:03 PM
I will swap them around tomorrow and see what happens..and thanks for telling me the flow rate..that's quiet a difference.
#15 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 09, 2015 - 07:14 PM
Seems everything on this tractor is heavy and super tight..not like the GTs I am use to.
