1964 sears custom 600 [brass float]
10 replies to this topic
#1 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted March 18, 2011 - 05:28 PM
Does anyone know where i can buy a brass float for a 1964 sears custom 600. I've been told they are smaller than a normal brass float and are obsolete. This is the only thing left to do on it ,and it's ready to come out of retirement. I'm in Ontario Canada thanks.:wallbanging: 6hp tecumseh
Edited by pchili4, March 18, 2011 - 05:34 PM.
#2 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted March 18, 2011 - 06:29 PM
a 1964 custom 600 would have a tecumseh HH60. You can find a few engine with the same or similar float. I dont think they sell anything new for that engine.
#3 caseguy OFFLINE
  • 1,627 Thanks
Posted March 18, 2011 - 06:34 PM
I believe that they used the same type of carburetor on several Tecumseh engines. If you could find the model of the engine, it might be easier to figure out. I did a quick internet search and found that the model # of the tractor should be 917.9951. Then I searched Sears Parts Direct and came up with a Sears part # for the engine, but dead ended there. If you could find the Tecumseh model number (should be an H60, and HH60, an HS60...or something like that, include the spec # which will be a dash something{5 or 6 digits} after the model #) Then we could dive into what carb should be on there through Partstree or a similar site and go from there. Hope to help if I can.
#4 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted March 20, 2011 - 08:06 PM
[attachment=9008:9653.attach]Hi caseguy thanks for diggin in on this.I tried brazing the carb and fileing it as best i could and so far so good but i feel its just a temporary fix.I had it out running around having some fun with it, and it sounds great and runs solid.I am still going to get some numbers and see if you can find something for me, if your still ok with that thanks.
#5 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted March 22, 2011 - 09:39 PM
neat old tractors aint they. That 900 is in the best condition I have ever seen a 600 in.
#6 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted March 23, 2011 - 04:57 PM
Sorry,I'm confused,what do you mean by 900
#7 caseguy OFFLINE
  • 1,627 Thanks
Posted March 23, 2011 - 05:39 PM
...I am still going to get some numbers and see if you can find something for me, if your still ok with that thanks.
Yes absolutely! I am sorry it took me a couple of days to get back...been really busy the past few days. Ready when you are!
#8 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted March 23, 2011 - 07:17 PM
Its a custom 600
#9 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted April 08, 2011 - 07:59 AM
Hi caseguy sorry it took awhile to get back to you.It was too cold here so i thought i would flee to Cuba for a couple of weeks.So the model number on my 1964 sears custom 600 is 143-546072or could that 546072 be 5A46072 its hard to tell , and serial number is 3325 05147 and the other model number on it is 917 99500 thanks for helping.
#10 MH81 OFFLINE
Posted September 28, 2011 - 07:47 PM
I will be up at my Dads sometime this weekend. I have a Custom 6 up there with the same engine I think. If someone jogs my memory on Friday, I will see if there are any numbers on the carb.
Pchili4, please send me a PM if you still need the info.
#11 MH81 OFFLINE
Posted October 02, 2011 - 11:00 PM
The only info I could find ( on an old carb ) are the letters LMB raised in the casting. The bowl is a smaller size with certainty.
Good luck with the search.
  • tractorman604 said thank you
