Repower of a 6512.5 - need help with wire connection
simplicity 6512.5 repower briggs and stratton
4 replies to this topic
#1 JPFever OFFLINE
JPFever
  • 2 posts
Posted April 07, 2015 - 06:56 PM
My original engine has failed after 25 years of use.  I have decided to repower my SImplicity with a newer Briggs engine.  The new engine is a Model: 49T877 Type: 0006G1.  What I need help with is what wires from the original harness connect to the new engine harness.
From Tractor harness:
Gray - Same connector with Red/White - Originally connected to serrator
Red/White - Same connector with Gray - Originally connected to serrator
red/yellow - to engine block
Black/white - to coil
On new engine
Black/gray - to coil
gray - to fuel pump
red with red jumper - to voltage regulator
Any idea how to hook everything up?  Mowing season is right around the corner.
Thanks
#2 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted April 08, 2015 - 07:14 AM
I will take a go at this
1- alternator part number 592830 should have 2 wires going into a yellow connector that connect to voltage regulator 845907
2- .wire from voltage regulator to battery needs to be fused
3 - fuel shut of solenoid part number 798779 should have 12 volts when start switch is in on position
4- Coil should have a kill wire that stops engine when connected to ground through safety switches and start switch.do not apply 12 volts to coil wire.
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 08, 2015 - 08:07 AM
:welcometogttalk: An Ohm meter will go a long way.
  • jms180 said thank you
#4 JPFever OFFLINE
JPFever
  • 2 posts
Posted April 08, 2015 - 05:00 PM
1- correct have this connection
2- from voltage regulator (engine harness]: red wire w/jumper fused to where?
3- fuel shut off will have black/white wire connected to gray (12volts when switch is on)
4- coil (black wire on engine harness) will have red/yellow wire as kill wire.
From tractor harness this leaves me with 2 wires that may or may not need connection.
In the same connector with a red wire (12volts when switch is on) and gray wire (0 volts on or off) which do one hooks to the voltage regulator (red wire with jumper)
#5 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted April 08, 2015 - 07:51 PM
the red wire from voltage regulator connects to positive on battery may go through the switch some do . it is fused in case of a short circuit in the charging circuit. Could be fused before start switch on B terminal. The case of the voltage regulator in negative or ground.
Edited by jms180, April 08, 2015 - 08:02 PM.
Also tagged with one or more of these keywords: simplicity, 6512.5, repower, briggs and stratton
