Simplicity 7116 mower deck belt help
6 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted April 07, 2015 - 06:01 PM
How do I hook the pto belt up?
#2 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted April 07, 2015 - 06:28 PM
You can go to our Manuals Section and find the manuals. You may need to find the manual for the particular attachment. Good Luck, Rick
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted April 07, 2015 - 08:59 PM
Does the 7116 have a front pto, or is the deck driven off the left side of the BGB?
#4 Simpleton OFFLINE
Simpleton
  • 120 Thanks
  • 78 posts
Posted April 07, 2015 - 09:35 PM
My 7114 mower is driven off the pully on the left side of the BGB. There are two other pullies right there with it. One is at a slight angel. The belt comes from the center of the mower deck to the side of the tractor so the angel pully comes into play first to direct the belt to the drive pully.
Once you get it it's quite "Simple".
Sould be a diagram on the mower deck.
  • Cat385B and alec have said thanks
#5 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 07, 2015 - 09:44 PM
and there is a lever next to the rear tire that loosens and tightens the belt.
  • Simpleton said thank you
#6 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted April 08, 2015 - 05:57 PM
There was a diagram on the mower deck just didn't look at it till today
#7 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 09, 2015 - 09:23 PM
This manual is for an earlier mower and tractor but is going to be the same procedure. Note: belt sizes will be different than on 7100 series. http://www.simplicit..._00_AT_S_LO.pdf
