Blown bladder
17 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 07, 2015 - 10:58 AM
Well Frankin Tractor seems to have blown a bladder seal on the backhoe and I have no clue where to get parts or even what parts to order...This always seems to be an issue with the odd ball stuff I seem to acquire.
This machine is a Dig-it 188T(tractor is a Ingersoll 6018 with a dig it backhoe..any ideas out there?
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 07, 2015 - 11:06 AM
  • MH81, LilysDad and Bolens800uk have said thanks
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 07, 2015 - 11:12 AM
Do a search for Dg it backhoe and see if any dealers, parts suppliers or even repair articles/videos come up. You could also try a local hydraulic shop. They should be able to sort it out for you.
  • boyscout862 and Auburn David have said thanks
#4 MH81 OFFLINE
Posted April 07, 2015 - 11:24 AM
Looking on the case of the cyl might give you a number?
  • Auburn David said thank you
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 07, 2015 - 11:36 AM
I looked,didnt see a # unless its in a spot I cant see..will give it a good look over when I remove it.
#6 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted April 07, 2015 - 11:38 AM
X2 I would just pull the whole ram off and bring it to a hydraulic repair shop. Most of time they will put all new seals in it cheeper than the dealer will want just for the part to do it yourself.
  • boyscout862, WNYTractorTinkerer and Auburn David have said thanks
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 07, 2015 - 11:44 AM
Cant find anywhere around here that rebuilds/repairs them.
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,536 Thanks
  • 6,199 posts
Posted April 07, 2015 - 12:15 PM
You live near any coal mines in Alabama?  There are hydraulic rebuild shops around areas with coal mines.  Mines have lots of hydraulics.
I had one of the vendors we use frequently for hydraulic repairs do a couple cylinders for me.  They made their own seals, packing, ect, and rebuild it cheaper than I could buy the OEM parts for.  I did NOT receive a discount as that is against our "gift and favor policy"(rightly so)  I paid the price anyone off the street would of paid.
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 07, 2015 - 12:51 PM
Nope..no coal mines here.
#10 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,536 Thanks
  • 6,199 posts
Posted April 07, 2015 - 12:53 PM
Figure you might of been near Drummond or jim Walter resource
#11 bh115577 OFFLINE
bh115577
  • 443 Thanks
  • 240 posts
Posted April 07, 2015 - 01:46 PM
If you find an online retailer of hydraulic cylinder seals and give them some accurate dimensions they will likely be able to get you whatever you need.
#12 Freddie1911 OFFLINE
Freddie1911
  • 149 Thanks
  • 98 posts
Posted April 07, 2015 - 05:12 PM
  David AutoZone loans tools, If you can get a spanner from them spin the cap off. You can then get your dims. Here Agri supply has a lot of seals and packings. Of course you do know on line.   Freddie       good luck
#13 EricFromPa ONLINE
EricFromPa
  • 4,011 Thanks
  • 3,267 posts
Posted April 07, 2015 - 06:05 PM
They're a few hydraulic repair and machine shops down there.Check the Online Yellow Pages.Here's a link.
http://www.yellowpag...quipment-repair
If you was a bit closer I would give it to one of my brothers to take into work.They both work at Harrisburg CAT Hymac division.They can get parts but CAT will charge ya $5,000-$250,000+  for machine work. :rolling: Those little cylinders are what they call "Throw away" because the machine work costs more than the cylinder is worth.
#14 Alc OFFLINE
  • 7,132 Thanks
  • 7,533 posts
Posted April 07, 2015 - 06:10 PM
Mission Manufacturing sells Dig It parts
#15 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 643 Thanks
  • 460 posts
Any quarries or sand pits near you? You could also check with local construction companies or municipalities, they might know of a shop around where your at.
