3 Point to Sleeve Hitch Adapter (Reverse of the Normal)
3 replies to this topic
#1 jdslednut ONLINE
jdslednut
  • 679 Thanks
  • 851 posts
Posted April 07, 2015 - 10:38 AM
I'm in the middle of a box blade build and am planning to make it a 3-point attachment with wishful thinking that I may find a 3 point for my JD 314.
I currently have the sleeve hitch for the Deere and would like to be able to mount the 3 point box blade with a sleeve hitch as well.  Does anyone have pics/dimensions/drawings any type of adapter that might do the job?  I've found tons of plans/pics of adapters that mount to the 3 point of the tractor to facilitate the use of sleeve hitch equipment but haven't had any luck finding the other direction.
Thanks!
Jeff
#2 KennyP ONLINE
  • 38,499 Thanks
  • 45,981 posts
Posted April 07, 2015 - 10:59 AM
Just put the u-shaped part on the box blade for a sleeve hitch.
You can buy one here.
  • jdslednut and Little Irish Men have said thanks
#3 jdslednut ONLINE
jdslednut
  • 679 Thanks
  • 851 posts
Posted April 07, 2015 - 10:55 PM
Thank you.  Just worried that by adding a simple sleeve hitch mount that I would be running too close to the tractor.  If I were to make an extension it would get in the way when I did get my 3 point.  I could fab it to bolt on.  I guess that might be an option.
#4 MH81 OFFLINE
Posted April 08, 2015 - 06:37 AM
I looked at this once too.
The big problem I ran into was the force from the toplink area. No good place to run a gusset to the sleeve hitch without making the adapter long and then you won't have the ability to pick it up.
