help to identify this motor
16 replies to this topic
#1 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 06, 2015 - 11:09 PM
I am in need of help identifying this motor.  I can't find any spec plates, stampings or other Id marks on this motor.  I bought this rusty turd just for a couple of implements that were attached to it and was planning on just junking the rest.  Well I was board a few weeks back so for the heck of it I tossed a fresh battery in it and much to my surprise it turned over.  so I gave it a few shot of either and hit it again and the dang thing fired off.  so now I guess I am going to save this rusty turd from the scrap pile.  I just don't know what to use as a motor type to get parts.  I am going to guess it is the motor that came in this 7010 simplicity but not sure.  I am wanting a rebuild kit for the card and points and cover.
any help would be great.
  • Alc, hamman, boyscout862 and 1 other said thanks
#2 petrj6 OFFLINE
petrj6
  • 4,076 Thanks
  • 2,369 posts
Posted April 07, 2015 - 04:47 AM
     Definitely a briggs Stratton, most likely a 10 hp 243400 series engine.  you should be able to find the serial # on the flywheel shroud up on top or down near the bottom on the carb side I think.  small stamped #'s.
  • Bolens 1000, hamman, boyscout862 and 1 other said thanks
#3 JDBrian OFFLINE
  • 9,595 Thanks
Posted April 07, 2015 - 05:08 AM
It has the head shape of an older Briggs. They have the numbers stamped into the tin and they can be hard to find if things are rusty and dirty.
  • hamman said thank you
#4 Alc OFFLINE
  • 6,136 Thanks
  • 7,036 posts
Posted April 07, 2015 - 05:15 AM
Welcome to GTTalk !!!   If  your need parts the check with some of the site sponsors , might be of help too
  • Bolens 1000 said thank you
#5 MH81 ONLINE
  • 29,496 Thanks
  • 29,563 posts
Posted April 07, 2015 - 06:37 AM
:welcometogttalk:
Thanks for joining up and introducing us to your diamond it he rough.
Odd thing here is that a manual (http://www.manualsli...?page=37#manual) says the engine is supposed to be a Kohler, but that looks like a Briggs to me as well. It may be different years, as they made these for several.
Hopefully a Simplicity Guru will happen along and help out.
#6 boyscout862 ONLINE
  • 11,108 Thanks
  • 8,278 posts
Posted April 07, 2015 - 06:39 AM
Welcome to GTT. That is a good model tractor and a great model engine(I have 6). Download this Manual to learn about it: http://gardentractor...ines-1919-1981/ Good Luck, Rick
#7 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 07, 2015 - 04:40 PM
This is an engine of the same vintage. The code number for the engine is right under the white label on the s/g side of fan shroud.
3734F839-A5B0-4502-9439-848B770187A7_zps
  • MH81 and classic have said thanks
#8 Bolens 1000 OFFLINE
  • 13,926 Thanks
  • 17,716 posts
Posted April 07, 2015 - 05:11 PM
:ditto:
Definietly worth saving!
Parts are still available for these Older Briggs and Stratton engines :thumbs:
#9 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 07, 2015 - 06:25 PM
well thank you skunkhome, it was right where you said it would be.  I was told ir was behind the carb and was looking over there.  after seeing you picture, I walked out and found it.  thanks so much
  • classic and petrj6 have said thanks
#10 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 07, 2015 - 06:28 PM
thanks to everyone for helping.  I will be posting pictures of her.  she is a rusty turd for sure, Mr Green has seen it.  heck he seen it before me.  I will make a new thread for it and you all can see the carnage
  • Rock farmer said thank you
#11 petrj6 OFFLINE
petrj6
  • 4,076 Thanks
  • 2,369 posts
Posted April 07, 2015 - 07:16 PM
   that is a good solid dependable motor !!  I have three or four of them.  you will love it.
#12 classic ONLINE
classic
  • 4,457 Thanks
  • 1,987 posts
Posted April 07, 2015 - 08:28 PM
Yup, that's a great engine and will have roller bearings on the crankshaft. That engine you have there is from 1977, due to the first two digits of the serial being 77. I'm rebuilding one from 78 that was used as a replacement engine on an Allis Chalmers Big Ten.
#13 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 07, 2015 - 10:14 PM
now if I just had a part number for the carb, I could get rolling on this thing
#14 classic ONLINE
classic
  • 4,457 Thanks
  • 1,987 posts
Posted April 08, 2015 - 07:20 AM
The carburetor part # is 391073 and the carburetor rebuild kit part # is 299720. Your carburetor should have four screws holding the top and bottom halves of the carburetor together.
#15 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 08, 2015 - 01:28 PM
is there a difference between a 391073 and 391074 carb?
