John Deer gone deep
9 replies to this topic
#1 UncleWillie OFFLINE
  • 16,127 Thanks
  • 8,915 posts
Posted April 06, 2015 - 02:16 PM
https://youtu.be/7GkBVRhw_9c
  • Jesse, tinbender7, Cvans and 2 others have said thanks
#2 greenb69 OFFLINE
greenb69
  • 270 Thanks
  • 210 posts
Posted April 06, 2015 - 03:21 PM
Shouldn't this be the other way around. The tractor pulling out the two jeeps. That's a lot of tractor to be pulling with anything other than a dozer.
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 06, 2015 - 04:20 PM
I'd say a little judicious use of tru tempers and 2x12's in front of all 4 tires, then pull w/o the stuck one spinning the tires would have gotten the bottom of the tractor lifted off the mud. Then it would have walked right out once the tires were on the 2x12's and he SLOWLY applied power.
JMHO,
Mike
#4 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted April 06, 2015 - 04:40 PM
I say he planted that Deere hoping it would multiply!
#5 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 06, 2015 - 05:08 PM
That's why they paint them green, so when they get stuck like that nobody sees it to laugh.
#6 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted April 06, 2015 - 05:43 PM
When have u ever seen that taken a running start with a tow strap working out well? Or spinning your tires as fast as u can?
#7 UncleWillie OFFLINE
  • 16,127 Thanks
  • 8,915 posts
Posted April 06, 2015 - 06:02 PM
If you have the right kind of strap a good jerk can help. Spinning the tires was just stupid especially since they were not spinning fast enough to clean themselves out.
  • Coventry Plumber said thank you
#8 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted April 06, 2015 - 06:57 PM
Once the frame is on the ground its gonna get hard. I would have used the backhoe to lift the front end and through some big rocks under the tires then do the same to the back.
#9 wilberj ONLINE
wilberj
  • 5,054 Thanks
  • 5,615 posts
Posted April 06, 2015 - 07:02 PM
One D8 and it would of been over in 15 min....
#10 jacobd OFFLINE
jacobd
  • 49 Thanks
  • 69 posts
Posted April 06, 2015 - 09:03 PM
The jeeps were ridiculous. All they needed to do was chain a stout timber or pole or something to the front two wheels and gently ease themselves up and out a few feet at a time. Just keep repositioning the pole in front of the tires and repeat as necessary.
