Bready walk behind with Lauson engine.
8 replies to this topic
#1 ACBIG10 OFFLINE
ACBIG10
  • 4 Thanks
  • 9 posts
Posted April 04, 2015 - 10:15 PM
I have a Bready walk behind with a Lauson engine. I was wondering if anyone knows anything about these. I believe it's from the early 1950s the engine is locked up. I do plan on restoring it cosmetically, but I don't plan on ever having it run.
  • CharlesDes said thank you
#2 DougT OFFLINE
DougT
    Dog Approved
  • 7,116 Thanks
  • 5,079 posts
Posted April 04, 2015 - 11:26 PM
I don't recall Bready ever using a Lauson engine. the majority were Briggs. How about posting some pictures?
  • Lauber1, boyscout862 and superaben have said thanks
#3 Tbrooks OFFLINE
Tbrooks
  • 508 Thanks
  • 326 posts
Posted April 05, 2015 - 10:17 AM
that is correct,bready's used either briggs or clintons depending on the model.
  • Lauber1 said thank you
#4 Tbrooks OFFLINE
Tbrooks
  • 508 Thanks
  • 326 posts
Posted April 05, 2015 - 09:19 PM
Here are a few specs on the bready's
  • drbish said thank you
#5 ACBIG10 OFFLINE
ACBIG10
  • 4 Thanks
  • 9 posts
Posted April 06, 2015 - 04:46 AM
Oh okay, well that is a bit of a relief. The engine is locked up. And it looks like it was taken off. So it could have been replaced 40yrs ago a d then sat outside uploadfromtaptalk1428313588638.jpg uploadfromtaptalk1428313594419.jpg uploadfromtaptalk1428313602489.jpg uploadfromtaptalk1428313606388.jpg
  • Alc, Lauber1 and Tbrooks have said thanks
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 06, 2015 - 07:38 AM
Bready's are non-existent around here.
#7 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted April 06, 2015 - 06:00 PM
Oh okay, well that is a bit of a relief. The engine is locked up. And it looks like it was taken off. So it could have been replaced 40yrs ago a d then sat outside attachicon.gifFB_IMG_1428313447483.jpgattachicon.gifFB_IMG_1428313437670.jpgattachicon.gifFB_IMG_1428313428382.jpgattachicon.gifFB_IMG_1428313417774.jpg
well even if its not the original engine , its still a fairly collectable one. I wouldn't be to fast to discard it, even if it is stuck.
#8 ACBIG10 OFFLINE
ACBIG10
  • 4 Thanks
  • 9 posts
Posted April 06, 2015 - 08:31 PM
Oh no I am planning on restoring the tractor and engine together. Unless I find a running engine for the tractor they will stay together.
#9 ACBIG10 OFFLINE
ACBIG10
  • 4 Thanks
  • 9 posts
I've never seen one in person other than mine.
