How to get this off? Front pulley?
4 replies to this topic
#1 robert kiernan OFFLINE
robert kiernan
  • 1 posts
Posted April 04, 2015 - 07:02 AM
Would anybody now how to get this off?
#2 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted April 04, 2015 - 12:32 PM
Steering wheel puller would probably work. :welcometogttalk:
#3 Jazz ONLINE
Jazz
  • 2,401 Thanks
  • 1,446 posts
Posted April 04, 2015 - 02:56 PM
Holes looks pretty close for a steering wheel puller but I would try that first...if not easy enough to make puller for something like that.. I have had to make numerous tools over the years for single purpose application,,I label them to remind me what they are for...
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 04, 2015 - 03:38 PM
If the steering wheel puller doesn't work, countersink the bolt head that goes in the crankshaft and use a two or three jaw puller if the jaws will reach to the other end of the pulley. If not then using whatever the 3 bolts hold for a pattern, drill matching holes in a 10mm plate w/ a hole in the center large enough for the crank bolt head to pass thru. Make the plate large enough diameter to drill 2 or 3 holes for the steering wheel puller.
I'm curious and need to know what the engine powers w/ such a small pulley?
Mike
#5 Guest_Thesandmanisme_*
  • Guests
Posted September 01, 2015 - 01:04 PM
If you can get a puller on it, and tighten it up. Smack it with a wooden mallet. A lot of times the pulley will pop right off. You can always heat the pulley with a propane torch. Not the shaft, just the pulley. This expands the metal pulley enough to use the puller.
