For Sale
1977 Cub Cadet 1450: Full Run of Attachments
No replies to this topic
#1 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 03, 2015 - 09:09 PM
As some of you know, I am trying to sell away some of the restoration projects that I know will never get accomplished by me.  The tractors will only go to heck in a handbasket sitting in an open face shed.
IMG_20150324_183733_390.jpg IMG_20150324_183744_476.jpg IMG_20150324_183753_128.jpg IMG_20150324_183812_710.jpg IMG_20150324_183825_033.jpg IMG_20150402_200253_150.jpg IMG_20150402_200303_017.jpg IMG_20150402_200312_503.jpg IMG_20150402_200323_787.jpg IMG_20150402_200333_720.jpg IMG_20150402_200342_243.jpg
This Cub Cadet 1450 was one that I bought with the idea of actually keeping.  I wanted a tractor that was big enough to use as a shop mule but also had all the attachments that I would ever need.  I changed my mind because (for one) I actually need something with a front end loader and forks.
I bought the tractor from the original owner's nephew.  The nephew had it only hooked to the tiller.
The 1450 has the Kohler K321 quiet line engine.  It runs great.  I rebuilt the carburetor, ignition system (coil, condenser, points, plug wiring, etc) and serviced the entire unit.  It does want to vibrate a little bit.  The engine mounts may be going out, but it really only does it at idle.  It smooths out at higher RPM.
The attachments:
~Tiller
~Mowing deck
~Snow blade
~Snow blower
~Brinly Hardy one bottom plow
~Sleeve hitch assembly
~Wheel weights
~Tire chains
The tractor comes with all the manuals, too!
All the attachments are in great shape.  I hooked up the tiller and used it.  I did not hook up the mower deck, but from spinning the bearings it feels and sounds smooth as silk.  I don't see any reason for the snowblower to have any issues.  The paint is barely worn off the auger.
I am asking $1900 for the whole package.  I can help with delivery for a little something depending on how far we need to go.
Ben W.
Edited by superaben, April 03, 2015 - 09:10 PM.
