Electrolysis
12 replies to this topic
#1 bgkid2966 OFFLINE
bgkid2966
  • 1,409 Thanks
  • 1,330 posts
Posted April 03, 2015 - 05:09 PM
Here is a link to an article on rust removal. This may have some tips which have not already been covered.
http://www.familyhan...olysis/view-all
Geno
#2 IamSherwood OFFLINE
  • 8,385 Thanks
Posted April 03, 2015 - 05:20 PM
Maybe I missed it, but it sure would be good, if they touched on these issues
before someone gets hurt.
taken from Olcowhands article.
  • Texas Deere and Horse, bgkid2966 and Sawdust have said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 11,825 Thanks
  • 8,940 posts
Posted April 03, 2015 - 05:25 PM
The article you posted tells how to deal with it. Take it outside. What I want to know is how to get a mower deck in a plastic garbage can.
  • bgkid2966 said thank you
#4 KC9KAS OFFLINE
KC9KAS
  • 5,161 Thanks
  • 4,545 posts
Posted April 03, 2015 - 05:27 PM
A really small deck and a really large garbage can.
  • bgkid2966 and LilysDad have said thanks
#5 Sawdust ONLINE
Sawdust
  • 5,315 Thanks
  • 3,241 posts
Posted April 03, 2015 - 05:46 PM
A childs plastic swimming pool from wallys world might work of coarse throw it away when done or never let the kiddies use it.
#6 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted April 03, 2015 - 05:56 PM
I'd experiment with a simple wood frame and poly sheet.
I have no idea how long it would last, but, all things considered, it only has to last long enough.
Edited by Chopperhed, April 03, 2015 - 05:57 PM.
  • bgkid2966, LilysDad and Sawdust have said thanks
#7 chieffan OFFLINE
  • 8,400 Thanks
  • 5,810 posts
Posted April 03, 2015 - 06:37 PM
I use this method and found that it works best if you start fresh with each item you clean, within reason.  Dump the water, clean the anodes good, and clean the tank, pail or container what ever size it may be.  I have tried to skim the top and add more soda but it don't work.  I use a 5 gl. pail for small items and 30 gal mineral tub for large items.  For a mower deck, better get you an old fuel barrel and cut it in half.  Your chemical cost is 0
#8 karel OFFLINE
karel
  • 1,827 Thanks
  • 1,214 posts
Posted April 04, 2015 - 04:17 AM
Has anyone heard of , or used the method involveing  molasses as s rust remover?
Edited by karl, April 04, 2015 - 04:19 AM.
#9 Texas Deere and Horse OFFLINE
  • 14,594 Thanks
  • 15,426 posts
Posted April 04, 2015 - 02:40 PM
I use a 42" X 42" X 42" liquid tote, hold 300 GA. with the top cut out of it for my really big stuff. It will hold a complete John Deere 200-300 series fender pan and do it in one shot. I lined mine with expanded metal sheets, pieces I had left over from jobs and it works well for my anode. The tote also has a 1" ball valve drain built into the bottom of it to drain the water out.
  • IamSherwood, KennyP, bgkid2966 and 3 others have said thanks
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 11,825 Thanks
  • 8,940 posts
Posted April 04, 2015 - 03:19 PM
What does a liquid tote cost?
#11 KC9KAS OFFLINE
KC9KAS
  • 5,161 Thanks
  • 4,545 posts
Posted April 04, 2015 - 05:14 PM
I used to get a speciality chemical in 275 gallon totes and the chemical manufacture didn't want them back...too much trouble to ship back  and re-use, so I gave them away.....Other-wise they cost around $300.
Check with a water or waste-water utility or a plating business. They use LOTS of chemicals and maybe have a tote to get rid of!
  • LilysDad said thank you
#12 3v0 OFFLINE
3v0
  • 102 Thanks
  • 89 posts
Posted April 04, 2015 - 05:30 PM
When they build concrete roads the wet concrete is coated with wax which comes in these containers.   Some companies give the containers away.
#13 Texas Deere and Horse OFFLINE
  • 14,594 Thanks
  • 15,426 posts
Posted April 04, 2015 - 09:14 PM
I get mine from a company that gets liquid smoke in them. They don't charge me for them.
