Easy Make Linkages
3 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted April 02, 2015 - 07:03 PM
 I came across this idea yesterday needing to make a leveling rod assembly for my MTD 990 deck. It could also be used making linkages. Using foundation anchor bolts, these are 1/2" diameter & come in 6"-10" & 12" lengths. If you need a length in between these sizes you could as I will have to do is cut the threads deeper down the shank & cut off the extra threaded length. You could simply drill the appropriate hole for the pin. They are usually a few bucks with nut & washer.
  • Alc, hamman, KennyP and 10 others have said thanks
#2 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted April 02, 2015 - 08:08 PM
That's a great tip.
  • Sawdust said thank you
#3 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted April 03, 2015 - 05:38 AM
Great idea!
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 03, 2015 - 06:50 AM
Yep! that's a good one. Those bolts are available in pretty much any building supply store and are cheap.
