got some work done on tractors today.
1 reply to this topic
#1 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted April 01, 2015 - 11:47 PM
worked on steering on the blue st10 tonight a little. fixed one issue found another. this is issue i fixed. this is the steering arm its bent pretty bad. now i noticed the gears arent meshing right so i got to looking and someone bent the plate holding the steering shaft. i got to figure out how to fix it or think of something else.i think i got an idea how to fix the gear meshing issue longer bolts and washers to raise steering gear to mesh with fan gear properly. then i worked on the yellow st10 and got rest of wires strung up made a bracket to hold the gasline up, and looked at its steering to see how far off the blue ones is and its about a 1/2 inch off lol.
  • Bud, Gtractor and boyscout862 have said thanks
#2 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted April 02, 2015 - 06:58 PM
since the plate connecting steering shaft to frame is bent wrong from someone poundind on it i took 8 washers 4 on each bolt and 2 new bolts and raised steering gear up and its meshing perfectly with fan gear now.
