OhNoAnotherNightmare
onan
17 replies to this topic
#1 Bud OFFLINE
Bud
  • 387 Thanks
  • 410 posts
Posted March 31, 2015 - 05:35 PM
Is that what Onan stands for?  Went to start the MF1655 today to get ready for tilling. It would start but not stay running so up goes the hood. The air cleaner houseing barely on by one remaining screw. The other two I don't think I want to know. So what does everyone else do to keep these screws in. I thought about locktite but I have to pull the air cleaner too often?
  • Gtractor, MH81 and FrozenInTime have said thanks
#2 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted March 31, 2015 - 05:39 PM
Blue silicon works well,and is easy to remove when the need be.
  • Bud, Alc and KennyP have said thanks
#3 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted March 31, 2015 - 05:40 PM
lock washers would also help.
  • Bud said thank you
#4 propane1 ONLINE
propane1
  • 7,145 Thanks
  • 3,580 posts
Posted March 31, 2015 - 05:48 PM
Goop is what I use. Noel
#5 KennyP ONLINE
  • 32,253 Thanks
  • 42,033 posts
Posted March 31, 2015 - 06:45 PM
Also, take a piece of aluminum screen wire and form it over the intake. That will keep the engine from digesting the screws!
  • Bud, limebuzz, LilysDad and 2 others have said thanks
#6 Gtractor ONLINE
Gtractor
    The Tractor Hoarder
  • 7,734 Thanks
  • 4,323 posts
Posted March 31, 2015 - 07:38 PM
ever-so-slightly bugger up the threads on the screws.  Then they act like self lockers and won't vibrate out.
Don't cost a dime - after you replace the missing ones.
#7 FrozenInTime OFFLINE
FrozenInTime
  • 614 Thanks
  • 379 posts
Posted March 31, 2015 - 09:43 PM
Last time one of mine went missing, I found it under one of the valves.  Looked today, another one is missing... good grief.  Really starting to like my new bota.
  • Bud and EricR have said thanks
#8 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,563 Thanks
  • 1,094 posts
Posted March 31, 2015 - 09:59 PM
Tack a small flat washer on edge to each screw head, then safety wire all three together after they are tight. I just thought of this so I think I'll do it to the Onan on my welder.
Mike
Edited by ol' stonebreaker, March 31, 2015 - 10:00 PM.
  • Bud, IamSherwood and oldedeeres have said thanks
#9 Bill 76 ONLINE
Bill 76
  • 1,763 Thanks
  • 1,120 posts
Posted March 31, 2015 - 10:50 PM
Vibratite----comes in a small bottle with a brush in the cap,brush it on threads and let it dry and put it together.I used it on Hilborn injection for years.
#10 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted April 01, 2015 - 12:19 AM
Honda repower.
#11 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,173 Thanks
  • 5,770 posts
Posted April 01, 2015 - 07:49 AM
Run it without it! Who needs clean air? :bigrofl:
#12 Bud OFFLINE
Bud
  • 387 Thanks
  • 410 posts
Posted April 01, 2015 - 09:46 AM
Thanks for all the good tips, they led me to this. I found and bought some 10-32 x 3/8 fillister screws with drilled heads. I can run a wire through all three screws. Like seen on some injector pumps. That way they won't come out and I won't worry about over tightening them and ruining any threads.
#13 Bud OFFLINE
Bud
  • 387 Thanks
  • 410 posts
Posted April 01, 2015 - 12:19 PM
Also the two missing screws were holding the valve open on #1 cylinder. Thankfully there doesn't seem to be any harm, even the screws are not messed up. They will go into the spare parts box.
  • IamSherwood and KennyP have said thanks
#14 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,563 Thanks
  • 1,094 posts
Posted April 01, 2015 - 02:27 PM
You're lucky they didn't make it into the combustion chamber.
Mike
  • Bud and KennyP have said thanks
#15 olcowhand ONLINE
  • 37,229 Thanks
  • 30,214 posts
Posted April 01, 2015 - 03:21 PM
I use the star type toothed lock washers on mine & haven't had one come loose since doing so.  I like to use blue Loctite also.....with the toothed washers.
  • Bud, limebuzz, IamSherwood and 1 other said thanks
Also tagged with one or more of these keywords: onan
