Best Carb Kohler 16hp
10 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted March 30, 2015 - 06:34 PM
Is a Carter really that much better than a Walbro carburetor?
I have a Massey MF16 that has a Walbro on it and it just doesn't have that smooth steady sound to it at high rpm.
It has a good smooth idle at about 1800 to 2200, that's what the Massey owners manual says to set it at.
From Idle to 1/2 throttle it has good response and runs smooth.
From idle or 1/2 throttle to full it sputters, surges before it smooth's out and even then every so often sputters a bit. Doesn't have that smooth steady sound to it at full throttle 100% of the time.
I've done everything else I can think of, ignition, governor, mixture, leaks vacuum+head gasket, last thing was to bypass the fuel pump, it failed 2 days ago.
My other MF16 has a Carter on it and when it was running last yr it was always smooth and steady, all speeds and with different loads on the engine, it's my grass cutter. It also has the fuel pump bypassed.
I think I'm gonna try swapping carbs and see what happens.
So my Question is > Is a Carter really better than a Walbro on a Kohler 16hp engine?
  • superaben said thank you
#2 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,149 Thanks
  • 10,210 posts
Posted March 30, 2015 - 06:46 PM
I think you answered your own question. The Walbros that don't have an adjustable main jet can't be adjusted for temperature variations.
#3 propane1 ONLINE
propane1
  • 9,476 Thanks
  • 4,408 posts
Posted March 30, 2015 - 07:18 PM
Are they the same # carburetor. #30 for a 16 hp, as far as I know. I have three 14's, one 16, one 12 and one 10. All have the adjustable high speed needle. All engines start differently and all operate different and sound different at different loads. Some of that could be because , they all have different mufflers. Maybe the mufflers are different on yours. All so sounds like it's running just a little lean on the mixture. Adjust top no load at 3600 rpms high speed jet a little rich, that some times helps the acceleration from idle to full speed. Just some thoughts, Noel.
Edited by propane1, March 30, 2015 - 07:25 PM.
  • IamSherwood said thank you
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,149 Thanks
  • 10,210 posts
Posted March 30, 2015 - 07:22 PM
No, Walbros have different #s.
#5 propane1 ONLINE
propane1
  • 9,476 Thanks
  • 4,408 posts
Posted March 30, 2015 - 07:26 PM
Oh, Noel.
#6 EricFromPa ONLINE
EricFromPa
  • 4,193 Thanks
  • 3,367 posts
Posted March 30, 2015 - 08:07 PM
Carter #30 is what you want.
Those darn Walbro carbs suck.They won't hold a low steady idle and no matter what you do they will Always try to stall out the engine on bumpy uneven ground.It's just the way they are manufactured.
The Walbro carbs with the Fixed main jets are the worst for boggin down on bumps and what not.When you hit a bump it chokes the jet of fuel.
Walbro carb parts are alot cheaper if you ever need them.Some Carter parts are a bit pricey like the main needle and float.Even though you can get aftermarket parts they will not always work the way you need them to.Especially the main needle.
  • superaben and propane1 have said thanks
#7 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted March 30, 2015 - 09:00 PM
My Walbro has adjustable jets, high and low, looks like this.
My Carter looks like this.
#8 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted March 30, 2015 - 10:00 PM
here are the setting for the screws
they are for only for setup and you have to adjust the screws to make it run the best you can
each carb is will act different - I have found that no two carbs of the same model act the same.
  • propane1 said thank you
#9 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 30, 2015 - 10:21 PM
It doesn't matter what brand, you want an adjustable carburetor.
Walbro makes great ADJUSTABLE carburetors.  They were one of the best.
But no fixed jet carburetor is good on an old engine.  An old engine has character, and you have to meter the fuel to match it.  The modern engines have a lot more science behind them, and they can make a fixed jet carb work.
You've got the nice style Walbro.   The EPA down here doesn't let Walbro make them anymore.
Ben W.
  • lyall said thank you
#10 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,149 Thanks
  • 10,210 posts
Posted March 31, 2015 - 07:29 AM
I have found that it's best to adjust a carb with a tach to get it perfect.
#11 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted April 12, 2015 - 05:47 PM
Today I spent some time and switched carbs, removed the Walbro and installed the Carter off my other Kohler 16hp and what a difference.
Smoother, steadier, no spiting, sputtering and higher top rpm.
I took the bowel off he Walbro to see inside and it looks clean, why it don't run right I don't know.
All I can say for sure is My Carter works better than My Walbro.
  • IamSherwood and KennyP have said thanks
