Belt on a 2284
8 replies to this topic
#1 cnsolutions OFFLINE
cnsolutions
  • 5 Thanks
  • 15 posts
Posted March 30, 2015 - 01:37 PM
Hello everyone,
Last year I purchased a 2284 with a 60" deck it has been a nightmare for me, the tractor runs great but I can't keep belts on it the PTO belt jumps off of the upper groove and goes down to the lower groove where the deck belt is and shreds.  I have replaced the belts 4 times I have also replaced the mule drive pulleys and deck drive pulley.  With the cost of the belts I can't keep doing this any ideas.
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted March 30, 2015 - 02:50 PM
:welcometogttalk: Any excess movement anywhere?
#3 sly_42 OFFLINE
sly_42
  • 28 Thanks
  • 16 posts
Posted March 30, 2015 - 04:09 PM
Can you get a straight edge in there to see if the pulleys line up when the deck is up and down.
#4 Bolens 1000 ONLINE
  • 15,291 Thanks
  • 18,235 posts
Posted March 30, 2015 - 04:11 PM
This will probably sound like a dumb question but are you using a Genuine Cub Belt?
  • superaben said thank you
#5 cnsolutions OFFLINE
cnsolutions
  • 5 Thanks
  • 15 posts
Posted March 30, 2015 - 05:33 PM
Thanks for the greeting I'm glad to be here. Yes the belts seem to line up and yes I'm using Cub Cadet belts they are way over priced.  The belt pops off immediately if the grass is too high and after a 1/2 to 1 hour with normal height grass then it seems to keep happening after the first time.  I have to mow around 10 acres.
#6 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 30, 2015 - 10:16 PM
You've done all the right things so far, replacing the belt and pulleys.
Once a belt learns to jump, it will keep on as a rule.  I don't know physically why it is, but it seems like they have a memory.
A belt will only jump if the pulleys are misaligned or if it has too much slop.
My guess is that you have a broken hanger on your deck or possible the front tensioner is too loose.  I'm not for sure what a 2286 would have, but that is what I have seen on other machines.
Ben W.
  • Bolens 1000 said thank you
#7 KennyP ONLINE
  • 40,130 Thanks
  • 46,764 posts
Posted March 31, 2015 - 08:57 AM
:wave: Welcome to the forum! Maybe some pics are in order. A link to a video for uploading them is in my signature.
#8 cnsolutions OFFLINE
cnsolutions
  • 5 Thanks
  • 15 posts
Posted March 31, 2015 - 11:13 AM
When I get home today I will upload some.
#9 cnsolutions OFFLINE
cnsolutions
  • 5 Thanks
  • 15 posts
Posted March 31, 2015 - 04:20 PM
Here are the pictures I took.
