I worked on the old Page tractor today.
27 replies to this topic
#16 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted March 31, 2015 - 08:50 AM
This tractor looks like it has smaller tires and a different hub.
  • Alc, Traill95 and Columbia236 have said thanks
#17 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted March 31, 2015 - 01:32 PM
The hubs are just reversed. I've seen them installed both ways on the pics I've seen so far. I worked on the engine this morning and it's alive! The points and condenser were crusty, the points plunger was stuck, and the old three leg armature was a crusty mess. I had another 3 leg armature, points and condenser. I cleaned the flywheel magnet, freed up the points plunger, and installed everything. I also changed out the carb with a known good one. I gave it a shot of starting fluid and it ran for a second. I installed a clean sediment bowl and a new fuel line and put gas in the tank. I gave the rope a pull and it started right up! I adjusted the carb and took the tractor for a ride. Man is this thing a snail, but all of the gears work and it's a fun little machine to drive. I have to hook up a kill switch and choke and throttle cables now.
Edited by classic, March 31, 2015 - 02:01 PM.
  • Alc and Traill95 have said thanks
#18 glgrumpy OFFLINE
  • 8,606 Thanks
  • 7,913 posts
Posted March 31, 2015 - 04:00 PM
I thought Page was beginning of Wheel horse and brother did Speedex? No connection on these? Wait, lite came on, Pond is who I'M thinking of. NEVER MIND!!
  • Traill95 said thank you
#19 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted March 31, 2015 - 08:24 PM
I've been noticing that the rear fenders have been mounted at different heights on some of the Page tractors, and some have different fender mounts. There are other differences also. There is red paint under the orange paint on my engine, so I'm thinking it's the original engine, and my tractor may have been made in '64 or '65,due to the engine date code.
Edited by classic, March 31, 2015 - 08:26 PM.
#20 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted March 31, 2015 - 09:17 PM
What is the rear tire size? also what model Briggs engine?
#21 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted March 31, 2015 - 09:47 PM
The rear tire size is 7-16, and here is a pic of the engine tag. The engine is a Briggs 23 DFB.
Edited by classic, August 26, 2015 - 07:02 PM.
#22 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted April 04, 2015 - 07:01 AM
Page tractor running.:
  • MH81, Traill95 and Columbia236 have said thanks
#23 MH81 OFFLINE
Posted April 04, 2015 - 12:39 PM
Just so you know yours was the last post before the server shutdown. I wish I could say you won something, but I can't
Nice page, sounds good.
  • Traill95 and classic have said thanks
#24 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted April 04, 2015 - 01:37 PM
I musta hit the eject button or sumpthin'. What on earth happened? Thanks for the comment on the Page MH.
  • MH81 and Traill95 have said thanks
#25 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 12, 2015 - 12:38 PM
Tire size and engine (Briggs 23) point this tractor to a Red-E model P-15
#26 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted April 12, 2015 - 03:27 PM
Thanks a lot Adam, you have been a big help.
  • bread320i and Traill95 have said thanks
#27 oldiron1 OFFLINE
oldiron1
  • 423 Thanks
  • 268 posts
Posted May 05, 2015 - 10:30 PM
Hey Classic,
I see you had your flywheel cover off, which I need to do on my Red E with a similar Briggs engine but am having troubles, never doing this before and wondering if you could help.
My big question is how does this pulley come off? I took the big nut off the front and assuming it is pressed, tried to use a 3-jaw puller and managed to break a chunk off the pulley lip (darn, I'm mad at myself for that one) but it didn't budge. I don't think it's keyed, but seeing the nut on the back side, wonder if it's threaded?
Thanks, Rob
#28 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted May 05, 2015 - 11:11 PM
I sent you a message Rob. A picture of your pulley will help us figure it out. I might be able to locate another pulley to replace your broken one, too.
