Ford T-800
50 replies to this topic
#16 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted May 30, 2015 - 10:33 PM
I am wanting to finish the front grill up. My head light trim rings are chrome. They will need to be redone. What are some recommendations. I would like to get them redone but I heard chrome plating is getting expensive
#17 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted June 07, 2015 - 09:06 PM
Does aNY one know where I can get a Kohler K181 id plate for the motor. I would like a new one I can get stamped with my orginal #
#18 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted June 08, 2015 - 11:30 AM
http://gardentractor...14152-mike912e/
He had some plates not sure if he still does or not. Tell him I told ya about them.
#19 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted June 27, 2015 - 08:31 AM
I am getting ready to lay some paint on the frame this week. Since I am trying to do a good job, Does any one out there rebuild the Jacobsens transmissions?
#20 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted June 27, 2015 - 09:22 AM
I am block sanding and filling as I go. I am not looking for a showroom piece, but a piece that center be shown. It's a tractor and will be used as one
  • VintageIronCollector said thank you
#21 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted July 03, 2015 - 07:38 PM
What's the best blue paint? Has anyone shot tractor supply ford blue?
  • tinbender7 said thank you
#22 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted July 03, 2015 - 07:57 PM
yes I have, becarefull there 2 Fords blues a lighter one for the earlier Fords and a darker one for the later Fords, I think the break off is the open sides are lighter and the closed sides are the darker. TSC carries both
#23 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted July 03, 2015 - 08:56 PM
How does it spray?
#24 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted July 03, 2015 - 09:16 PM
I have used the rattle can and a spray gun, i like the spray gun best, for a small job the rattle works ok
#25 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted July 04, 2015 - 08:11 AM
I have a hvlp so I will go that route. Once the frame is painted it's easier to get motivated. Sand, paint install part.
#26 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted July 04, 2015 - 09:45 AM
Picked up the paint this morning. Raining hard outside so no spraying for a few days.
#27 Dayton_King OFFLINE
Dayton_King
  • 1,181 Thanks
  • 1,027 posts
Posted July 19, 2015 - 09:28 AM
Question. Would you guys paint the frame and then install the clutch and implement lift? Or install those and then paint. I am thinking the paint will prevent me from sliding them on?
#28 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted July 19, 2015 - 03:01 PM
Personally, I would paint then try to slide on and touch up areas when you get it on. But if you want to do it a way that would work for sure paint after you put on.
#29 KennyP ONLINE
  • 37,530 Thanks
  • 45,524 posts
Posted July 19, 2015 - 03:06 PM
I'd install anything that goes through the bushings (etc.) then paint. You can always tape off what you don't want paint on!
#30 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted July 19, 2015 - 03:16 PM
I found that Tremclad Royal Blue was a nearly exact match for my open side 145. I matched it to unexposed parts and it was too close for my old eyes. Careful prep and application can yield a pretty good paint job.
