new guy with 2 1855s
118 replies to this topic
#61 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 17, 2015 - 08:46 AM
The second Snapper 1855 is in the garage. I will take pics some time today. Only. Pic I have at the moment is the rear discharge deck, it's a Massey deck. All the spindles are good. Need the 2 outside pulleys which I have a stock pile and the it's ready to rock and roll
  • olcowhand and limebuzz have said thanks
#62 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 17, 2015 - 10:48 AM
The tractor pictures. The 3 point lever is broke and the seat pan was cut. But it was defiantly taken care of. I will not paint this one I will buff and wax
  • olcowhand said thank you
#63 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted May 17, 2015 - 01:46 PM
The valve on my 1650 was the same way. I disassembled the valve and took the shaft to a good machinist. He parted off the broken piece and made a new one to go on it. Center drilled the shaft and tapped it 10X32, same for the new piece. A little bit of red loctitie and we were done. Its been holding well for 2 years now.
You could also weld it up and drill it back out.
#64 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 17, 2015 - 02:14 PM
Sweet thanks. My screw up for the day I sold the center pulley a few weeks ago because I didn't think I needed it. Well I do. So I will buy one on epay. I am rebuilding 6 spindles to have spares. So I will install all new parts. I will also need to buy 54# timed belts and blades. Then I am ready to rock and roll.
Working on the 3 point install. I will paint and install everything over the next week or so.
#65 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted May 17, 2015 - 05:27 PM
 I've never tried to buy new blades yet,but the folks say that are NLA!?!? I will be eding a set by fall. Good luck with the blades.
#66 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 17, 2015 - 05:54 PM
Ebay has blades for the 48. I didn't realize my rear discharge deck was a 54 in till I started digging into it.
#67 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted May 17, 2015 - 09:20 PM
I used some 18 1/2 inch blades with a 3/4 inch center hole. I made spacers fro each blade to take the center hole to 5/8, thats what my spindle bolts are. The shear pin holes did not line up so I tack welded the blades to the holders. That seems to be working pretty good, the welds break when i find rocks in the grass. Next set of blades I think I will try drill out for the shear pins, couldnt drill the blade holder , its hardened.
I will try to get the numbers off the blades in the next day or so.
  • limebuzz, ENafziger and Dayton_King have said thanks
#68 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 21, 2015 - 06:57 PM
I have 1 spindle rebuilt. I thought I had more oil seals but I dont, I will get it at Napa. I have 5 more to rebuild. I am soaking the spindles in vinegar and clean them up as I go. I bought a new center spindle. I am hoping to have it mowing by Tuesday or Wednesday.......
#69 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 22, 2015 - 10:42 AM
Napa has the oil seals, so on my way home I will pick them up. I like it when a plan comes together
  • limebuzz and KennyP have said thanks
#70 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 23, 2015 - 11:58 AM
I have rebuilt all my spindles, installed the new center pulley and my good outside pullies. I have only 1 belt. No one has them so it's a special order. Next weekend I could be mowing
The tractor is patiently waiting
  • limebuzz said thank you
#71 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted May 23, 2015 - 03:22 PM
From one of our members (Mac102004). A cross reference page for the belts. The last ones I got were gates off of amazon.
https://sites.google...massey-ferguson
Edited by coldone, May 23, 2015 - 03:23 PM.
  • Dayton_King said thank you
#72 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 23, 2015 - 06:45 PM
I ordered the gates from Amazon earlier today. I was frustrated, I wanted to mow this afternoon. I put new plugs in the Snapper, runs strong
#73 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 24, 2015 - 06:39 PM
I am buying a set of spool valves from another 1855. I will figure out how to fix the one and do a 3 valve spool.
#74 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 24, 2015 - 06:40 PM
#75 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 28, 2015 - 08:17 AM
My newest problem. I ordered a belt for the 54" deck. I just got notified that the manufacturer has to make more and I won't see my belt till middle of July. Does any one have a good used 54" deck belt they can sell me. I have the deck already to go but the one dang belt
