new guy with 2 1855s
118 replies to this topic
#31 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 13, 2015 - 03:13 PM
I bought a pto switch today, I still need to buy all the safety switches. Here are some pics of the mower deck. Both outside pullies are shot. The center one is mint. The drive shaft is wore out literally. It's been welded on. So what's yours guys verdict, I have a bunch of pullies and all the bearings to rebuild the deck. Do I save the shell and what do you think of the drive shaft?
#32 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 13, 2015 - 08:26 PM
I am diving into my box of goodies. I have a bunch of mower deck parts I bought as a package. It also cane with this pulley. What does it got to? The guy owned a Snapper 1600
#33 Cat385B OFFLINE
    Tractorfanatics.com
  • 14749 Thanks
  • 10288 posts
Posted April 13, 2015 - 08:43 PM
Wow, is that driveshaft wallowed! Is that 7/8" x 3/4" shaft with a 15 spline coupler?
#34 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 13, 2015 - 08:51 PM
I have no idea of of size don't have a tape at home
#35 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted April 14, 2015 - 03:54 AM
Single or double groove?
#36 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 14, 2015 - 04:28 AM
Single groove
#37 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted April 14, 2015 - 06:25 AM
It will be for the top of the center pulley on the deck that runs from  engine. Drive pulley if  you will.
Edited by limebuzz, April 14, 2015 - 06:26 AM.
#38 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 14, 2015 - 06:40 AM
Ah, well guess that's no good to me lol
#39 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted April 14, 2015 - 08:40 AM
Driveshaft is a 1" shaft  and uses a 3/4 x 11 spline coupler. Only place I found them is Surplus Center. I bought one then had a local driveshaft place build me a new one since they couldn't find replacement u joints.
If you can do fab work, cut that deck up and move the center spindle a few inches forward. You can then use standard pulleys and not worry about the cogged timing belt or pulleys that are NLA.
that pulley kind of looks like one to the rear PTO, but I would have to look at my parts bin.
Edited by TAHOE, April 14, 2015 - 08:41 AM.
  • Sawdust said thank you
#40 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 14, 2015 - 01:29 PM
I have maybe 6 good times pulleys. My drive shaft is great on the tractor. It my mower drive shaft that is shot. It was made non serviceable. I will try to take it off and drop it off at a drive shaft shop and see what they can do
  • TAHOE said thank you
#41 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted April 14, 2015 - 07:41 PM
As a person that has recently rebuilt a 54 inch snapper deck, use the money for another mower. The biggest problem after you get the deck rebuilt is that the blades are NLA. I had to sub in some other blades. I had to make spacers for the bolt holes and then tack weld the blade to the holder. The drive pins for the subs do not line up with the drive pins on the holder. No drilling the holder,it is hardened. The deck scalps bad due to not having an antiscalp wheel on the front. Scalping tears up the belts. The Pullies are NLA except for the center double, its like $250.
Just had to reweld the tack welds tonight because of hidden rocks in the yard.
Of course, as I am typing this I just thought about drilling the mower blades to fitt the old pins,so there is that option instead of welding.
#42 adolphsson09 OFFLINE
adolphsson09
  • 258 Thanks
  • 327 posts
Posted April 15, 2015 - 02:24 AM
I also have a deck that probably needs rebuilt and after looking into the cost I just went and bought a new mower just for mowing instead and I use the snapper 1855 for the tilling and snow blowing
#43 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 15, 2015 - 06:29 AM
Well, I guess I will take all the good parts off. My other 1855 has a smaller deck and is in much better shape. I think I will start hoarding deck parts
  • limebuzz said thank you
#44 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted April 15, 2015 - 05:09 PM
No no, thats what I am doing. :D
#45 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted April 15, 2015 - 06:02 PM
Lol well I will tell you what, I have some blades for the big deck, there are some nicks but I think there usable ;) won't work on my other deck
