Changed oil now it wont run
7 replies to this topic
#1 Afbrown OFFLINE
Afbrown
  • 3 Thanks
  • 12 posts
Posted March 28, 2015 - 01:22 PM
My lawnmower has a 16hp opposed twin briggs and stratton motor, i just rewired it and it had ran fine the other day i killed it changed the oil the next day and now it wont start, its got spark and compression with no signs of a dirty carb, it doesnt even react to starter fluid, i cant figure out whats wrong. Any advice would be appreciated.
#2 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted March 28, 2015 - 01:29 PM
from my past experiences its probably a seat safety switch, oil sensor shut off, or possibly you just left it in gear? ( which I have done,duh ) both those sensors you can jump. as for being in gear you can just shake your head. ha ha !!! ps ,did you add enough oil also clean the oil sending unit, hope this helps, it sounds like an easy fix, another thought is your key switch grounding out
Edited by farmer john, March 28, 2015 - 01:36 PM.
  • tinbender7, HANKG and karel have said thanks
#3 jms180 OFFLINE
jms180
  • 1,507 Thanks
  • 1,563 posts
Posted March 28, 2015 - 02:13 PM
I could send you a repair manual that may help.
  • tinbender7 said thank you
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted March 28, 2015 - 02:14 PM
Since you have done some rewiring recently I would suggest you go back and make sure all your connections are good and tight, no broken wires and all your grounds are good.  As a side note please do not by-pass any safety switches they are there for a reason.
  • IamSherwood, tinbender7, boyscout862 and 1 other said thanks
#5 MH81 OFFLINE
Posted March 28, 2015 - 04:40 PM
Check to make sure no one bumped the oil sensor wire, the pto switch isn't in gear, the clutch is depressed when it should be, etc...
  • tinbender7 and Sawdust have said thanks
#6 chieffan OFFLINE
  • 10,107 Thanks
  • 6,621 posts
Posted March 28, 2015 - 07:34 PM
Are  not most of the safety switches on the starter solenoid side and not the ignition?  If it has spark I would guess it turns over.  If this is true that eliminates any safety switch.  I would put in a new plug as you could have fire with the plug out, but it is not firing under pressure.
  • MH81 and tractorgarden have said thanks
#7 Afbrown OFFLINE
Afbrown
  • 3 Thanks
  • 12 posts
Posted March 28, 2015 - 08:17 PM
Ive already wire around everything but there is one thing i dont really know what it is, i will post a picture and see if someone can identify it and how to get around it. It has pretty new plugs, ps this mower is never going to mow again the deck was ruined so im turning it in to a mud mower, thanks everyone for your help hope someone can identify that piece once i get a picture of it posted.
#8 dodge trucker ONLINE
dodge trucker
  • 2,423 Thanks
  • 3,116 posts
Posted March 29, 2015 - 11:34 AM
Having spark in the ignition system, or not has nothing to do with "turning over"  Not being locked up, and the crank spinning when the starter is activated (pull or electric) is  all that  "turning over" means. Whether it fires, or tries to start has nothing to do with "turning over".
I do not get where people say "starter cranks, but engine does not turn over"  something that I see in many for sale ads and "help-it don't run" kind of  posts.
