New to me 990
34 replies to this topic
#1 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 485 posts
Posted March 28, 2015 - 03:04 AM
Finally got me a 990.
Think I stole it.
Easy part was already done repainted.
Hard part lies ahead teardown and clean the frame and repaint.
go through all pivots and linkages,front spindle upgrade.
you know everything the last owner overlooked.
Going to rebadge it as a JC Penny
reason being its been repainted JD yellow,and
Have not seen many.JC Penny tractors
All I need is to find decals.
Pics are off the net and only closely represent how it started
and what I want the finished product to look like
  • Alc, Texas Deere and Horse, hamman and 5 others have said thanks
#2 Alc ONLINE
  • 7,221 Thanks
  • 7,576 posts
Posted March 28, 2015 - 06:11 AM
Never saw a JC Penny one so thar going to be pretty cool !
#3 boyscout862 OFFLINE
  • 13,545 Thanks
  • 9,425 posts
Posted March 28, 2015 - 06:43 AM
There may be a page out of an old Penny catalog showing it. HDWildBill scanned and posted a bunch for me a couple of years ago. Good Luck, Rick
#4 Bolens800uk ONLINE
Bolens800uk
  • 1,844 Thanks
  • 1,208 posts
Posted March 28, 2015 - 07:48 AM
I wish I got te 990 when I had the chance a few weeks back but bought a Bolens Ride a Matic instead. Looks an absolute steal that one. Look forward to seeing its developments.
#5 VTXrider OFFLINE
VTXrider
  • 534 Thanks
  • 390 posts
Posted March 28, 2015 - 08:53 AM
Nice find. I hope your restore goes well. Would love to see pictures as you progress.
  • 1oldbuzz said thank you
#6 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted March 28, 2015 - 09:43 AM
Congratulations on a great find. I'm just finishing mine up so if there's anything  we can help with just ask. I can't see the rest of your hood badge. It looks like the one I have a Turf Trac ??? The Penny's badge is harder to find. There are some out there you could maybe get the graphics off of so you could have them printed. So far that's the only way I have seen folks do this. Can't wait to see more pics of it.  :thumbs:
  • superaben and 1oldbuzz have said thanks
#7 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 485 posts
Posted March 29, 2015 - 03:09 AM
I turned it into a pile of parts.
Sorry no pics but we all know what a pile of parts looks like,lol.
Surprisingly everything came apart without breaking.
Years of lack of maintenance has taken a toll
Left front spindle was so tight I could hardly turn it,(steered ok)which in turn
took it out on the steering sector.
Hopefully I can rebush rebuild it.
Other than that most of the other pivot points and such aren't the worst for its age.
Now to clean off 35 plus years of grease and grime buildup.
Should have pics of reassembled and painted frame in a few weeks.
  • Texas Deere and Horse and Sawdust have said thanks
#8 Texas Deere and Horse ONLINE
  • 14,881 Thanks
  • 15,514 posts
Posted March 29, 2015 - 10:05 AM
Does it have the hole in the frame right in front of the trans axle mount on the right side? If so, make sure you check that area for stress cracks as they most all cracked there from use. I always liked the Penny's paint scheme because it's so different.
#9 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 485 posts
Posted March 29, 2015 - 10:49 AM
No hole  there
Was told this is a 1977
can't prove it by the numbers
they are gone.
But have seen enough posts speaking of this.
Alas I am a welder by trade and I always find myself adding welds
if it looks like it needs.more or better.
Can't believe some of these machines have held together
for 35 plus years with the way some of the welds look!
#10 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted March 29, 2015 - 01:39 PM
Check your engine code number on the shroud. The first two numbers will be the year of the engine which in most cases will be the same as the tractor give or take a few months.
#11 Texas Deere and Horse ONLINE
  • 14,881 Thanks
  • 15,514 posts
Posted March 29, 2015 - 02:22 PM
Yes, the engine is usually 3 to 6 months older then the tractor, unless it was around model year change. But it will give you a close idea of the year model of the tractor.
  • Sawdust said thank you
#12 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 485 posts
Posted March 29, 2015 - 05:38 PM
Thought of that.
But no tag and no other numbers or codes found yet.
Engine I do believe to be the original.
#13 VTXrider OFFLINE
VTXrider
  • 534 Thanks
  • 390 posts
Posted March 29, 2015 - 05:40 PM
Your engine numbers should be on top of the fan shroud near the spark plug or on the side of the shoud below the carb. Not a tag but stamped into the metal.
Edited by VTXrider, March 29, 2015 - 05:43 PM.
  • Sawdust and 1oldbuzz have said thanks
#14 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 485 posts
I have a theory on the hole.
need to look at my 960 a little closer to verify.
#15 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 485 posts
Posted March 30, 2015 - 03:22 PM
Hers my theory one the hole in the frame.
I have a 72
and a 74
Both 960's they both have a hole
I do believe this is to access the brake adjustment .
Now the 990 frame I have does not have the tell tail hole.
and the brake is father back on the tranny.
however I can see frame extenders were added to the tail end
needed due to the size of the rear end and different mounting.
Did MTD realize to late in production and produce a frame without
the hole for the 990's because of stress cracking.
  • VTXrider said thank you
