LT12H resto and re-build
72 replies to this topic
#61 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 24, 2015 - 01:08 PM
Thanks Charlie,
I did replace the needle when I did the carb kit, so I'll double check that I have it seating properly
There's also a "knob" on the end of the fuel line connector. Should this be all the way open or "tuned" somehow?
#62 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 26, 2015 - 05:38 PM
Took the float bowl back off and made sure the needle/seat are in there properly. I think there was a restriction on the float before
Still having spark issues though. I get nothing even though it's a new armature, business card air gap, and new spark plug. The coil itself looked great when I had the flywheel off. Puzzled...
On a side note I didn't get a good picture before disassembly of where this yellow wire should go.. I'm assuming it's a ground of some sort. I really don't think it goes where I have it in the picture
#63 KennyP ONLINE
  • 37,519 Thanks
  • 45,517 posts
Posted June 26, 2015 - 05:49 PM
Have you checked out the service manual for these?
#64 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 26, 2015 - 06:20 PM
The LGT12 is different isn't it Kenny?
I didn't see a manual specifically for the LT12H but I'm working through some of the Briggs manuals. That's one of the issues I'm having is I haven't found the wiring diagram for my specific tractor
#65 KennyP ONLINE
  • 37,519 Thanks
  • 45,517 posts
Posted June 26, 2015 - 06:22 PM
That says it is for the 12 & 17 HP Gear & hydro models!
#66 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 26, 2015 - 06:24 PM
Oh you're right! Thanks Kenny I'll download this one and check it out
#67 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 29, 2015 - 07:09 PM
Finally achieved spark!
New armature went in and I set the gap, re-checked the spark plug gap, and all the safety switches
I now have spark, but what seems like a timing issue. I backfire with each engine rotation
http://youtu.be/wRNL8U-ABik
#68 KennyP ONLINE
  • 37,519 Thanks
  • 45,517 posts
Posted June 29, 2015 - 07:12 PM
Quit eating beans!
#69 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 29, 2015 - 07:22 PM
That's a backfiring problem I can't get rid of!
Well the only thing I can think of is the camshaft, but I aligned it like so
Can bad carb adjustments cause backfiring?
#70 KennyP ONLINE
  • 37,519 Thanks
  • 45,517 posts
Posted June 29, 2015 - 07:36 PM
I had a K341 giving me all kinds of sass. Turned out the bushings on the throttle shaft were gone. So look into that!
#71 Chopperhed ONLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 30, 2015 - 04:27 PM
Yes a badly lean condition will cause backfiring on occasion. Especially if there is carbon in the combustion chamber. I suspect the combustion chamber is clean since you had it apart.
The other thing I would suspect is something holding the intake valve open.
#72 KennyP ONLINE
  • 37,519 Thanks
  • 45,517 posts
Posted June 30, 2015 - 05:07 PM
Or a hole in the muffler
#73 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 30, 2015 - 07:00 PM
Hole in the muffler?
I actually have no exhaust/muffler on it at the moment
I'm leaning towards not aligning the timing gear properly. I need to pull the engine again and check that out
