Broken bolt problem # 2 .......
5 replies to this topic
#1 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 5,985 Thanks
  • 2,714 posts
Posted March 25, 2015 - 03:41 PM
Here is what I have, I found something today I didn't see before and it is this slit in the spindle ...... does that mean I should have a wedge I could drive that out with ???
This is the chuck.
This is the bottom of the spindle where the bolt is broken.
This I found today. Wondering if this would drive out with a wedge?
Any suggestions or help appreciate.
  • CharlesDes said thank you
#2 Arti OFFLINE
Arti
  • 1,354 Thanks
  • 983 posts
Posted March 25, 2015 - 03:48 PM
You are correct that is for removing the chuck  Also you can buy Tapered Shank Drill bits, They just fit in there in place of the chuck..
  • hamman said thank you
#3 Bill 76 ONLINE
Bill 76
  • 1,763 Thanks
  • 1,120 posts
Posted March 25, 2015 - 04:14 PM
You chuck looks to have a Jacob taper that holds it to a morse taper that holds it in the spindle--Yes you just put a wedge in the slot and rap it with a hammer and it will fall out.To reinstall it just line up the tang with the slot in the spindle and give it a light rap with a brass hammer,you don't have to beat it in ,just a light rap,
  • hamman and boyscout862 have said thanks
#4 hamman ONLINE
hamman
  • 5,985 Thanks
  • 2,714 posts
Posted March 25, 2015 - 04:18 PM
Okay. Thanks. I am going to the garage and make a small wedge from a piece if steel I've got to get it out. I hadn't noticed this slit until today ! Once I get it out it will be easier ti deal with the broken bolt. Can't believe I didn't see this before. Thanks guys,        Roger.
#5 KennyP ONLINE
  • 32,209 Thanks
  • 42,021 posts
Posted March 25, 2015 - 07:25 PM
I have some of those wedges if'n you want some!
  • hamman and Sawdust have said thanks
#6 hamman ONLINE
hamman
  • 5,985 Thanks
  • 2,714 posts
Posted March 26, 2015 - 01:48 PM
Removed the spindle and chuck and found that there is a Mores taper on the upper of the spindle and a Jacobs taper on the bottom where the chuck fits on. I placed pictures on the #2 post so you can see what I found.
As I said in the first post I am most grateful for you guys and your knowledge. I have found over and over how knowledgeable and willing to help you really are. Thanks for being there for those of us who need some help and guidance.                             Roger
