Cub Cadet woes
10 replies to this topic
#1 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted March 25, 2015 - 09:41 AM
Went and picked up a Cub Cadet 1018 the other day. Complaining about oil coming out the fuel pump vent. (He) had already replaced the fuel pump. I checked the vent hose and the pump hose no problems noted. Noticed on a slight downward incline the engine smokes really bad. Pulled dip-stick and this engine huffs like a freight train and blows oil out of the dip-stick tube. Engine shows 166 hours on clock. Suggestions?
  • CharlesDes said thank you
#2 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted March 25, 2015 - 09:58 AM
Have you done a compression check? Shouldn't be with those hours but my initial thought based on that would be an issue with the rings allowing a lot of blow-by.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 25, 2015 - 10:22 AM
Carbon buildup will cause blowby as well but it's usually not an issue with an engine with low hours. It might be worth pulling the head for a look see, especially if the compression test is low.
#4 Bud W OFFLINE
Bud W
  • 326 Thanks
  • 303 posts
Posted March 25, 2015 - 11:12 AM
Check to see if the crankcase vent is venting. I had one that was left with the air cleaner off and the mud wasps got in the vent tube. When it was running, it puked oil out between the block and end cover. That was a Wisconsin but I'm sure the Kohler could do the same thing.
#5 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted March 25, 2015 - 11:38 AM
18hp OHV Briggs Intek or Vanguard single cylinder?
If it's smoking bad it either has a blown head gasket or Gas in the Oil.Or Both.
Never pull the dipstick out of a Vertical engine and start it or crank it over.You'll get covered in oil.The oil fills the bottom of the tube on these.When you crank it over the Piston creates pressure in the block and blows the oil out all over the place.
Try it with a Push mower it will do the exact same thing.
Head gaskets are $9-$15 and pretty easy to change.Don't forget to set the valve clearances after you install a new gasket.
Set both valves to .005
Briggs manual says Intake 0.004 – 0.006 in. exhaust 0.004 – 0.006 in.
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted March 25, 2015 - 01:00 PM
That's what I thought too. I'll check compression tomorrow and see what it is. What should it be? 18.5 hp single cylinder Briggs. It runs really well.
Edited by crittersf1, March 25, 2015 - 01:00 PM.
#7 IHCubGuy ONLINE
IHCubGuy
  • 1,536 Thanks
  • 1,601 posts
Posted March 25, 2015 - 08:28 PM
Could be a broken ring maybe.  We had a farm tractor once that had excess blowby.  Good mechanic told us pull the dipstick and if it pushes oil out you got broken rings.  Low and behold that was the problem and new rings fixed the problem.
#8 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted March 26, 2015 - 10:20 AM
Flat head (L-head) Briggs have a compression ratio of 6 to 1. Multiply that by atmospheric pressure (14.7 psi) should theoretically be about 90 psi.
OHV engines are 8.5 to 1 compression ratio so about 125 psi.
Disclaimer: This is obviously a very basic way of looking at it and there are a lot of variables such as valve overlap/timing, pressure at elevation, etc. and is a theoretical number at 100% efficiency but it should give you a base number to get in the ballpark.
If you get a compression number and you aren't sure just post the results
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted March 27, 2015 - 07:28 AM
Did a leak down test. Pulled head. Sure enough, blown head gasket. Waiting on parts.
  • EricR said thank you
#10 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted March 31, 2015 - 07:20 AM
1018 or 1810?....hmmm can we see a pic of it?
#11 IHCubGuy ONLINE
IHCubGuy
  • 1,536 Thanks
  • 1,601 posts
Posted March 31, 2015 - 02:54 PM
1810's didn't have an hour meter did they?  I bet he has a 1018.  That would be a lawn tractor about ten years old.
