JD 140 electrical problems... Help please!
140 electrical
18 replies to this topic
#16 thadbowen OFFLINE
  • 4 Thanks
  • 7 posts
Posted March 24, 2015 - 10:13 PM
Hey guys. I got it running! Finally!
I totally replaced the ground cable because I didn't trust that it was doing its job. Also while doing that I saw the wires going to the voltage regulator were worn and dried out by the conectors. So i replaced that last 2 inches so the bad wire was gone. After doing those two thing i got it to crank. Then i took the carb off and did a good cleaning. After that she fired right up. Its been sitting for 13 years!!
THANKS everyone for all the help!
You have gained a long time member here now that I have contracted the little tractor fever!!
  • Alc, KennyP, Trav1s and 1 other said thanks
#17 hdg4400 OFFLINE
  • 286 Thanks
  • 351 posts
Posted March 24, 2015 - 10:32 PM
Glad you figured it out.
I should have remembered my problem with starting my 318, but hindsight is always better than foresight. All of a sudden it wouldn't start, then with help from people here at GTTalk I figured it out.
While working on it, I had taken the battery out of the tractor and connected the tractor cables to the battery with jumper cables. Then it would start. Took me a little while but finally figured out the tractor cables weren't making a good connection to the battery posts.
After a good cleaning and smoothing/sanding of both the battery posts and the insides of the cable connectors. it worked much better. I still think I need a new positive cable, but haven't gotten around to getting one yet.
#18 M.Cain OFFLINE
  • 185 Thanks
  • 158 posts
Posted March 24, 2015 - 10:58 PM
Glad to hear you got her running .
Mitchell :dancingbanana:
#19 KennyP ONLINE
  • 39,186 Thanks
  • 46,336 posts
Posted March 25, 2015 - 04:55 AM
Glad you figured it out!
