73 economy hydraulic pump
11 replies to this topic
#1 73 economy OFFLINE
73 economy
  • 2 posts
Posted March 24, 2015 - 04:53 AM
I have a 73 that I am in the process of restoring. Hydraulic pump for years has worked at times and eventually locked up. Took the pump to a local hydraulic pump rebuilder He said he could not help. Would like to retrofit a newer pump. Does anyone know what the pressures and specs are on the original pump? Or even possibly what I can order through Northern hydraulics.
#2 KennyP ONLINE
  • 30,443 Thanks
  • 41,043 posts
Posted March 24, 2015 - 05:37 AM
:wave: Welcome to the forum! I may have a manual for that, I'll have to look. The folks here like pics, so check out the link in my signature.
Edit: I found a manual for a 1971 Hydraulic lift. I'll upload it to the manuals section.
Edited by KennyP, March 24, 2015 - 05:42 AM.
Added Comment
#3 Alc OFFLINE
  • 5,813 Thanks
  • 6,822 posts
Posted March 24, 2015 - 05:41 AM
Welcome to GTTalk !!!
#4 HANKG OFFLINE
HANKG
  • 5,276 Thanks
  • 2,939 posts
Welcome to GTT we probably have a manual for that. Nice to see another Jersey guy here.
#5 Alc OFFLINE
  • 5,813 Thanks
  • 6,822 posts
Posted March 24, 2015 - 05:44 AM
Here's a link to a 1977 Power King brochure  might be the same as yours
http://gardentractor...r-king-tractor/
#6 KennyP ONLINE
  • 30,443 Thanks
  • 41,043 posts
Posted March 24, 2015 - 05:46 AM
Here's the link to the manual I just uploaded.
  • Gtractor said thank you
#7 boyscout862 OFFLINE
  • 10,335 Thanks
  • 7,828 posts
Posted March 24, 2015 - 05:55 AM
Welcome to GTT. You can download 3 manuals for free per day from our Manuals Section. Try Bailey Sales and the Surplus Center too when you are shopping for hydraulics. Good Luck, Rick
#8 KennyP ONLINE
  • 30,443 Thanks
  • 41,043 posts
Posted March 24, 2015 - 05:59 AM
I found another manual that lists a different pump brand for that period.
#9 KennyP ONLINE
  • 30,443 Thanks
  • 41,043 posts
Posted March 24, 2015 - 09:21 AM
What is the brand name & #'s off the pump? The '71 manual says it may be an MTE C-204-7. I found this info but not totally sure if it fits your pump.
The second file says they used a Webster 15YB00915-2R pump. I can find nothing as yet on that.
#10 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted March 24, 2015 - 10:19 AM
Without checking,the Century Fox pump was used pre-70 and the Webster pump took over directly after I think.The MTE pump may have been the high volume pump for the loader.
#11 73 economy OFFLINE
73 economy
  • 2 posts
Posted March 24, 2015 - 01:28 PM
Thanks for all the response. There are no numbers or names on the pump. My grandfather purchased the tractor and 82 and it never had a loader on it yet I'm assuming that it would be a smaller volume/pressure pump. Looking at the manual for the MTE pump The pictures and everything look the same as what I have. The next big question is where do I get one or parts to rebuild the one I have. I will try to find a picture of it before I took it apart two years ago and post it.
#12 glgrumpy OFFLINE
  • 6,970 Thanks
  • 6,735 posts
Posted March 24, 2015 - 03:31 PM
Don't think rebuildable. Some on epay most times. Output is low, like 1000lbs or close aND volume less than 2 Gpm. Shaft size and mount are biggest issues.
  • 73 economy said thank you
