Armature-Magneto
4 replies to this topic
#1 reedtravis88 OFFLINE
reedtravis88
  • 4 posts
Posted March 23, 2015 - 05:04 PM
My Ariens Lawn mower will not shut off when I put the ignition in the off position. I was just going to put a toggle switch in between the kill wire and the frame for an easy solution. As I researched armature and kill switches I see plenty kill wires for sale with two wires extending out (see picture). I don't understand where the extra wires go. Any help would be appreciated.
#2 boyscout862 ONLINE
  • 10,020 Thanks
  • 7,662 posts
Posted March 23, 2015 - 05:18 PM
Check the engine manual in our Manuals Section. I would suspect that the wire is broken. Check for continuity. Good Luck, Rick
#3 shorty ONLINE
shorty
  • 3,887 Thanks
  • 4,190 posts
Posted March 23, 2015 - 07:25 PM
What engine does your mower have?
#4 DougT ONLINE
DougT
    Dog Approved
  • 5,908 Thanks
  • 4,379 posts
Posted March 23, 2015 - 07:29 PM
I hope I am seeing a Briggs coil with the electronic trigger? (magnetron?) One wire would go to the small wire at the coil and the other would go to a good ground. You need to ground the small wire to turn it off. AND....Welcome to the forum!!
  • superaben said thank you
#5 dodge trucker ONLINE
dodge trucker
  • 1,492 Thanks
  • 1,943 posts
Posted March 24, 2015 - 08:52 PM
if it runs then the armature/magneto coil is not bad. the "not shutting off" is probably a broken kill wire somewhere (which comes off of the coil)
