Best choice GT for a loader Gear or Hydro
9 replies to this topic
#1 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 487 posts
Posted March 19, 2015 - 06:14 PM
Wasn't sure where to post or how to tittle.
What would be the better choice for a front end loader on a GT
gear drive
gear with high/low
or hydro
This GT bug has bit me good.
I have a kwik way loader for a sears SS/16
and the Sears SS/16
I am also going to have a MTD 990 in the stable
Now I'm undecided which one to install the loader on
  • Traill95, FrozenInTime, propane1 and 1 other said thanks
#2 Cvans OFFLINE
  • 7,308 Thanks
  • 6,392 posts
Posted March 19, 2015 - 06:26 PM
By far my choice is a foot operated hydro with the loader. You can get more work done in a shorter period of time with this combination.  Low range does come in handy here also.  Next would be a hand operated hydro.  The slowest is the gear drive with a lot of stick jockeying going on.
Edited by Cvans, March 19, 2015 - 06:29 PM.
  • Traill95 and propane1 have said thanks
#3 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted March 19, 2015 - 06:35 PM
I believe that if the loader goes to the SS/16 that it should be put back on it. Machines were usually designed to match to certain attachments. Moving them around can cause unexpected headaches. Good Luck, Rick
#4 propane1 ONLINE
propane1
  • 9,476 Thanks
  • 4,409 posts
Posted March 19, 2015 - 07:18 PM
Foot pedal hydro, as said. Same for snowblower too , in my mind. Noel
Edited by propane1, March 19, 2015 - 07:20 PM.
  • Cvans said thank you
#5 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted March 19, 2015 - 07:48 PM
Foot controlled hydro, hands down the best for a loader.  You always have one hand for the steering, and the other for the loader hydraulics.  Power steering is a HUGE plus as well.
  • Cvans and ENafziger have said thanks
#6 Rock farmer ONLINE
Rock farmer
  • 1,302 Thanks
  • 1,275 posts
Posted March 19, 2015 - 09:06 PM
Foot controlled hydro with power steering.
The bigger the better!
#7 FrozenInTime OFFLINE
FrozenInTime
  • 658 Thanks
  • 404 posts
Posted March 19, 2015 - 09:46 PM
I've used both, small and large tractors.  SOO much easier with the foot hydro.  I've ran large payloaders with hydro, I could not image how hard that job would have been if I would had to mess with a clutch.
  • limebuzz and Cvans have said thanks
#8 UncleWillie OFFLINE
  • 16,265 Thanks
  • 8,977 posts
Posted March 20, 2015 - 12:28 AM
I have done both on tractors and foeklifts the foot hydro is best. On a forklift the difference is even bigger than a tractor. Much easier to finess something up high on a rack with a hydro.
#9 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 487 posts
Posted March 20, 2015 - 03:28 AM
Thanks for the replies and input.
I was leaning towards the hydro myself,
but wasn't sure.
The loader I have was on a 990 when I purchased it.
I acquired the SS/16 a year later
Picking up a 990 later today, I hope(hasn't run in 2 years)depends how bad it looks/is in person.
Looked good in the pics.
I was also leaning toward putting it on the 990 due to its a heavier
machine.
And I have become spoiled with a hydro so much easier than the gear.
  • Cvans, boyscout862 and Rock farmer have said thanks
#10 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted March 22, 2015 - 02:50 AM
Put it on the 990. The more base tractor weight, the better. It also has a better transmission/rear end for loader work.
