Building Tooth Bar
8 replies to this topic
#1 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,138 Thanks
  • 2,406 posts
Posted March 18, 2015 - 09:34 PM
Well, I decided to build a tooth bar for my Kubota L2000 with Leon 400 loader, I'm planing on doing a lot of digging in the future and I think a tooth bar would be really handy to have. I'm using a new cutting edge and some nice rippers type thingamabobs for the teeth. I'm going to cut the teeth to length and weld them onto the new cutting edge that I'm bolting on.
After this project, I am then building hay forks so I can move around loose straw to the garden.
I'm hoping to get the tooth bar finished tomorrow and then start on the hay forks!.
Edited by BTS, March 19, 2015 - 11:30 AM.
  • Alc, wvbuzzmaster, Traill95 and 4 others have said thanks
#2 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted March 19, 2015 - 04:18 PM
The tooth bar will help digging
  • BTS said thank you
#3 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,138 Thanks
  • 2,406 posts
Posted March 19, 2015 - 08:51 PM
Got the tooth bar finished today, but I didn't get a chance to try it since it was dark.
Although it looks like it should work well!
Tomorrow I'm starting on the hay forks!
  • wvbuzzmaster and IamSherwood have said thanks
#4 shorty ONLINE
shorty
  • 5,290 Thanks
  • 5,170 posts
Posted March 20, 2015 - 05:28 AM
That will sure change the digging for the better. :thumbs:
#5 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,138 Thanks
  • 2,406 posts
Posted March 20, 2015 - 09:32 AM
Went out for a test drive with the tooth bar today! it dug really good in the hard packed driveway and it also ripped up the drive way really good!
#6 KennyP ONLINE
  • 37,542 Thanks
  • 45,531 posts
Posted March 20, 2015 - 09:47 AM
That should work!
#7 tater195 ONLINE
tater195
  • 2,078 Thanks
  • 1,379 posts
Posted March 20, 2015 - 11:20 AM
How does it work for leveling? I am used to seeing the teeth 75% on top of the blade 25% on the bottom. They cut the same but dont leave grooves as bad when doing the final grade
#8 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,138 Thanks
  • 2,406 posts
Posted March 20, 2015 - 12:22 PM
It seems to level pretty decent, I can just roll the bucket all the way back and level it out with the back of the bucket.
If I need to do very much leveling I will just use the box blade or the straight angle blade.
#9 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,138 Thanks
  • 2,406 posts
Posted March 20, 2015 - 10:12 PM
I got the manure forks done, I was in a real hurry getting them done and somehow I got the spikes different lengths??? When I got the spikes welded on, I realized that the spikes would be on backwards if it was on the right way and if I turned it around the so the spikes were the right direction then it wouldn't fit. So I just hurried and welded on a couple new mounts and I'll rebuild it later.
Anyway it seems to work well, I got a scoop of straw and manure/hay with ease!
Edited by BTS, March 20, 2015 - 10:15 PM.
  • wvbuzzmaster said thank you
