Likely causes of death..
25 replies to this topic
#16 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted March 25, 2015 - 12:57 PM
So i'm investigating the engine replacement option as well, and have come across a 12hp Briggs pulled out of a Craftsman (unknown year).
Are all the 12hp Briggs vertical shaft engines equivalent? It looks to me like the 12.5hp engine was when they shifted to the twin cylinders.
#17 tater195 ONLINE
tater195
  • 2,080 Thanks
  • 1,380 posts
Posted March 25, 2015 - 01:12 PM
The later one holer 14-18 OHVs might fit without much modification(longer block). Shaft diameter and length are the only thing that are critical. It seems the smaller 8-12 hp L heads are a little harder to find in good condition. Not sure if it is a design issue or they were abused more
#18 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted March 25, 2015 - 01:18 PM
when you say 14-18 you mean the larger displacement 14-18hp engines?
The engine I'm looking at would be replacing the 12hp Briggs in the Ford LT12H. I haven't looked at it in person, but from the picture it looks the same.
Are there different 12hp models? How do I determine if it's an L-head?
#19 tater195 ONLINE
tater195
  • 2,080 Thanks
  • 1,380 posts
Posted March 25, 2015 - 01:34 PM
L heads are the flat heads. The OHVs are the overhead valve engines they used in the newer cheap stuff that is ragged out by now. Engines are usually in good shape (other than needing valves adjusted), but the LTs are junk. They are easier to find and in better shape than most engines made 25+ years ago. 14-18hp single cylinder engines are the most common.
Edited by tater195, March 25, 2015 - 01:35 PM.
#20 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted March 25, 2015 - 02:32 PM
Ok so it seems to me that my tractor has a 12hp Briggs L head and this other engine is a 12hp ovc out of a craftsman
I think I'm better off tearing into mine and trying to get it running
#21 Hobal OFFLINE
Hobal
  • 19 Thanks
  • 41 posts
Posted April 19, 2015 - 09:29 PM
Seized doesnot mean broken. If the tractor gods are smiling it may just have heated up and gotten stuck if the oil level was too low. Pull the plugs check the oil and put a bar on the crank and see what it does. Just a friendly thought. Good luck with it!
  • aevansgatech said thank you
#22 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 24, 2015 - 09:49 AM
What do you mean by put a bar on the crank?
#23 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted April 24, 2015 - 10:44 AM
Pipe wrench and a cheater bar. see if you can get things to break free and move. Hope this helps.
  • Hobal said thank you
#24 Hobal OFFLINE
Hobal
  • 19 Thanks
  • 41 posts
Posted April 24, 2015 - 11:36 PM
Exactly, word for word.
#25 chevy57 OFFLINE
chevy57
  • 2 Thanks
  • 4 posts
Posted May 20, 2015 - 05:20 AM
It~s a  ford
#26 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,019 Thanks
  • 9,648 posts
Posted May 20, 2015 - 11:13 AM
Whew, expected something else when I clicked on this thread!
I was thinking driving on a hillside with the bucket up!
