Sears GT 19.9
10 replies to this topic
#1 Kraftsman OFFLINE
Kraftsman
  • 3 Thanks
  • 44 posts
Posted March 14, 2011 - 07:14 AM
Hello, Need some help with my sears. I had it running and was plowing it ran out of gas so I filled it up came back it restarted then died and now there is nothing when I turn the key I think its the solenoid. Looking for any other advice. And if anyone knows if the solenoid is really behind the dash under the battery plate? What a painful place to get too.
#2 MH81 OFFLINE
Posted March 14, 2011 - 11:30 AM
They really hid some of them. If you happen to have the model #, (917...) it might help us to see an exploded view online.
#3 Kraftsman OFFLINE
Kraftsman
  • 3 Thanks
  • 44 posts
Posted March 14, 2011 - 08:08 PM
I found mine but what a pain to work on here is the serial #917257080 hope this helps and thanks for trying
#4 MH81 OFFLINE
Posted March 14, 2011 - 09:06 PM
Boy, they really burried it, didn't they? On the upside, it looks to be readily available.
Don't forget to check the grounding at the solenoid, that can cause you some headaches too!
#5 Kraftsman OFFLINE
Kraftsman
  • 3 Thanks
  • 44 posts
Posted March 15, 2011 - 07:16 AM
Yes they did bury it, I will check the grounding seems to be okay. I need to pick up a new one. How does the steering wheel come off? If I can get that off I think I can remove the dash which would make life much easier it needs a new dash anyways.
#6 MH81 OFFLINE
Posted March 15, 2011 - 08:25 AM
Steering wheels are one of those "Problem Children" in this hobby. Most times guys destroy the the wheel, shaft or both getting it off.
#7 Kraftsman OFFLINE
Kraftsman
  • 3 Thanks
  • 44 posts
Posted March 20, 2011 - 01:01 PM
Fixed my Sears found where a wire with online fuse melted and allowed it to work intermittently fixed the wire, fixed my problem
Edited by Kraftsman, March 20, 2011 - 01:02 PM.
Missing word
#8 daytime dave ONLINE
  • 4,782 Thanks
  • 6,522 posts
Posted March 20, 2011 - 01:47 PM
:thumbs:Good for you. Makes you feel good when you find it was something not tooooo hard to fix.
#9 caseguy OFFLINE
  • 1,627 Thanks
Posted March 20, 2011 - 02:59 PM
...or too expensive! Congrats on getting it figured out! If the wire melted, you may want to be sure the fuse isn't too big. Just a thought!
#10 Kraftsman OFFLINE
Kraftsman
  • 3 Thanks
  • 44 posts
Posted March 21, 2011 - 01:29 PM
It was a great feeling to get her running right again and it was very nice and easy and cheap. thanks for the help everyone
#11 FF24GT6000Man OFFLINE
FF24GT6000Man
  • 14 posts
Posted April 09, 2011 - 11:13 PM
Glad you got it fixed! :)
