stick shift lgt120 ford
21 replies to this topic
#1 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 08:40 AM
hey guys just pulled my shifter on my transmission in my lgt120 ford had no gears clear of bull low moved the gears around with just my finger there all there but not sure if im missing something of the shifter it looks like it sets into something dose anyone know if theres something that hooks to the shifter all that is there is just rod that is tapered anyones help or could send me a picture of what should be there thanks
  • propane1 said thank you
#2 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted March 18, 2015 - 08:43 AM
Have you had a look at our Manuals section to see if there is a service manual for your tractor. If it has a Peerless transmission there is also a Tecumseh/Peerless manual in the transmission section that gives parts breakdowns and repair instructions.
#3 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 08:58 AM
i got the break down of the tranny but can seem to see if theres anything that has to be hooked on it just thought someone might know is there something that goes on the end of the stick to slid the gears back and forth i can slide them with my finger so maybe its got to be in the right spot its just the shaft on the end of stick with a grove in it
#4 tater195 ONLINE
tater195
  • 2,254 Thanks
  • 1,437 posts
Posted March 18, 2015 - 09:04 AM
If you can move it with your fingers, raise the back tire off the ground and take the belt off. Put it in any gear and spin the tire. Note the direction and speed of the pulley. Repeat for the other gears. I that works, the shifter may have jumped out of the socket or the tip busted off. If it doesnt work, you may have a busted shifter fork
Edited by tater195, March 18, 2015 - 09:06 AM.
#5 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 10:08 AM
wheres the fork on it and the shifter i got out it;s all there so is there  a fork that hooks to the shifter or is it build on the gears inside my shifter is rounded out like a lathe on the bottom which looks like it snaps in place on something the bottom ones when i slide it is like it snaps in and the top one moves really easy like you don;t have to push it as hard like it dosn;t lock in place
#6 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 18, 2015 - 10:22 AM
Some pics here would sure help folks see what's what. There is a link in my signature for help uploading the pics. I've never been inside one of these.
#7 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 11:46 AM
is there anyone out there that has a link on utube video on how to check shifter what it has on the end for a lgt120 ford garden tractor i think it;s around 1973  i can;t make heads or tails on the diagram of it
#8 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 18, 2015 - 01:34 PM
Don't know about a video, but I found this in our manuals. This manual, page 54
Hope this helps!
#9 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 02:42 PM
thanks so much
#10 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 02:49 PM
kenny is there any way you can send that transmission diagram again to me i can;t read it alot of the stuff to tell you what to do an see what goes where is missing if you could thanks so much
#11 propane1 ONLINE
propane1
  • 9,132 Thanks
  • 4,278 posts
Posted March 18, 2015 - 03:18 PM
Here are some pictures. Hope they are some help. I hate to ask this question and I know you have all ready checked, but are you sure that the belt is not slipping. May just need adjustment or replace. I had some trouble with mine , not quite the same problem as yours,but similar. Belt was slipping on mine.  Noel
  • blain said thank you
#12 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 04:14 PM
thanks so much  this will make more sense to me thanks again
#13 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 04:17 PM
no it;s not the belt its the shifter all i can get is low gear even when i put it in first or second its still in low gear and the shifter feels right sloppy on it it was jaming on me sometimes then the other day just got low only not sure what shifter hooks to maybe something let go
#14 blain OFFLINE
blain
  • 7 Thanks
  • 21 posts
Posted March 18, 2015 - 04:23 PM
is there a web site on that tranny i can get all what was sent to me in them pictures step by step what to look for and where every thing goes
#15 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 18, 2015 - 04:26 PM
That last I sent you has a link to the repair manual for that.
