simplicity 7112 electric lift ?
6 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted March 17, 2015 - 07:05 PM
my 7112 has electric lift and a mower deck . I have a 36 inch tiller I would like to put on it but cant seem to find any info on the cable length or layout . any help would be welcome . the manuals all exclude the electric lift portion
#2 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted March 18, 2015 - 06:46 AM
Do you have rear lift on the tractor today?  If not, the cable is only one component needed.  I just sold out of all the NOS rear cable lift kits I had, but might be able to find a picture & cable length.  A pulley is needed in the belly of the tractor to route that cable, or it will fray and snap in short order.  Any rear lift bracket from a Simplicity or AC will work (Except AC 300/400 series and early Homelite).
#3 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted March 18, 2015 - 12:31 PM
a picture or drawing ( even a sketch added to a parts breakdown picture) would sure help . one other question ... will it even lift the tiller ? and one other question ... can I use the manual lift when the electric one is hooked up ?
#4 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 03, 2015 - 07:36 AM
The standard manual lift uses the same rock shaft as the electric lift, so, no, it can't use both at the same time.
Edited by skunkhome, April 03, 2015 - 07:42 AM.
  • alec said thank you
#5 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 03, 2015 - 07:40 AM
See page 58 of this manual. http://www.simplicit...5_AT_SMA_LO.pdf
#6 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 03, 2015 - 11:44 AM
phil has come through again ! that has a bunch of stuff I need . thank you so much :thumbs:
#7 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 07, 2015 - 10:02 PM
made a cable and got a pulley for under the frame .put the tiller on and it lifts and lowers YAY ! now I need to put an additional pulley so it doesnt rub on the filter .... so close
