need some information on a 64 simplicity landlord
carburetor information
8 replies to this topic
#1 whiteeagle1978 OFFLINE
whiteeagle1978
  • 2 Thanks
  • 14 posts
Posted March 17, 2015 - 04:41 PM
Looking for a new carburetor motor info model 23d type 0129 01 serial # 54878.. looking for a part # for the carburetor or where is a good place to get one thanks for the help
#2 Talntedmrgreen OFFLINE
  • 3,101 Thanks
  • 2,201 posts
Posted March 17, 2015 - 05:01 PM
Are you sure you need one?  A new one will cost a boat load, but there are plenty of used ones, as they were used on engines for pumps, generators, etc.
here's a great resource:
http://outdoorpoweri...m_two_piece.asp
  • boyscout862 and whiteeagle1978 have said thanks
#3 boyscout862 OFFLINE
  • 10,335 Thanks
  • 7,828 posts
Posted March 17, 2015 - 05:02 PM
Check with our sponsors and mention GTT. For manuals check our Manuals Section. Good Luck, Rick
  • whiteeagle1978 said thank you
#4 whiteeagle1978 OFFLINE
whiteeagle1978
  • 2 Thanks
  • 14 posts
Posted March 17, 2015 - 07:59 PM
Ya it's bad gas leaking around the bowl after I put a new gasket on it .. I measured and the bowl is warped so air is getting in around the gasket
#5 Cat385B ONLINE
    Therapy CAT
  • 12,330 Thanks
  • 9,197 posts
Posted March 17, 2015 - 08:07 PM
3 or 4 bolt?
#6 whiteeagle1978 OFFLINE
whiteeagle1978
  • 2 Thanks
  • 14 posts
Posted March 17, 2015 - 09:20 PM
3
#7 Killer_A-C OFFLINE
Killer_A-C
  • 371 Thanks
  • 527 posts
Posted March 17, 2015 - 10:03 PM
I got a good carb off a early B10 if you need one..
#8 Alc ONLINE
  • 5,813 Thanks
  • 6,822 posts
Posted March 18, 2015 - 05:22 AM
Could you lay a piece of sandpaper on a flat surface , like pane of glass and lightly make figure "8"s with it you might be able to reuse the old bowel . I'm not sure if anything protrudes lower then the gasket area though which would make it had to do.
#9 whiteeagle1978 OFFLINE
whiteeagle1978
  • 2 Thanks
  • 14 posts
Posted March 18, 2015 - 09:51 AM
Ok so I got a part# for a carburetor it's 293950 that's ome looking online and I found that part # 390323 is that a aftermarket # can anyone tell me
