Jake Gets a New Battery Cover
jacobsen super chief 1450 jacobsen 1450 battery cover jacobsen battery cover
7 replies to this topic
#1 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted March 17, 2015 - 07:08 AM
From what I can tell in the parts pics, Jacobsen used wood blocks above and below the battery with a metal cover.
Considering this and the fact the battery would not fit all the way down on the frame, I built a steel lower platform when I first got the tractor. Yesterday, I wanted to finish this off with a cover, but I had made the lower platform too tall. I did a little investigating and found I could move the dash panel forward in the slotted holes in the frame. So I loosened the bolts holding the dash in place and slid it forward. This allowed me to rework the platform so it set the battery 3/4" above the frame just like a wood block would do. I added two 1/4" coupling nuts to the sides of the platform for some all-thread to screw into, thus holding things secure. The first 3 pics show the platform before I reworked it. I also saw an issue (first pic, center right) with a washer that could rub into the battery case, so I had added a plate between it and the battery.
I'll get a pic or 2 of the platform after rework today.
The top 'board' is a piece of the composite deck board. I used my little laminate trimmer and gouged out areas for the posts to fit into. Figured that would keep the metal cover from making contact with them. I also added 2 layers of 1/4" wood strips to allow some clearance for the vent caps on the battery.
Here is what it looks like in the tractor.
A little paint, a couple all threads, and some wing nuts will finish it off.
  • Gtractor, Alc, tinbender7 and 5 others have said thanks
#2 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted March 17, 2015 - 10:32 AM
Here's the reworked lower platform.
I'm thinking about putting a coat of Flex Seal on this. Don't know if it might help protect from the battery acid or not.
  • Sawdust said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,095 Thanks
  • 2,925 posts
Posted March 17, 2015 - 04:55 PM
Nice job! Is the whole tractor getting a repaint eventually? Or will it be wearing it's work clothes?
#4 KC9KAS OFFLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted March 17, 2015 - 04:57 PM
Nice fab work.
#5 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted March 17, 2015 - 05:08 PM
It would be nice to get some paint on it at some point! It's work clothes are pretty tattered!
  • TomLGT195 said thank you
#6 rustywrench OFFLINE
rustywrench
  • 19 Thanks
  • 30 posts
Posted March 17, 2015 - 06:44 PM
Looks nice!
#7 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted March 26, 2015 - 10:21 AM
Here's an update! I covered the inside metal with Black Flex-Seal. After the pics, I put several coats of Self-Etching primer on the top of the cover. I'm hoping to hide some of the dents from forming it.
  • Alc and TomLGT195 have said thanks
#8 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted March 26, 2015 - 05:42 PM
Looking good Kenny. :thumbs:
Also tagged with one or more of these keywords: jacobsen super chief 1450, jacobsen 1450 battery cover, jacobsen battery cover
