S24
11 replies to this topic
#1 Speedex 24 OFFLINE
Speedex 24
  • 1 Thanks
  • 5 posts
Posted March 15, 2015 - 06:15 PM
Hi I am new here. I have a Speedex S24 I am having starting problems. I put a new battery in it started a few times now it needs jumped everytime. Does anyone know what size battery I need or if it could be something else. It has a 10 HP Briggs with starter generator. I also have an 840 and 2 S19's
  • tinbender7 said thank you
#2 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted March 15, 2015 - 07:09 PM
Welcome to GTTalk. It sounds like you may have a problem with your generator/charging system. Have a look in our manuals section for operator or service manuals for your tractor. That may give you the information you need to troubleshoot the problem.
  I'm not a Speedex owner so I'm not much help with specific problems, but I'm sure someone with more knowledge of the S 24 will be along to help out.
  • tinbender7, boyscout862 and Speedex 24 have said thanks
#3 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 15, 2015 - 07:11 PM
Welcome aboard I'm not sure about your problems but doesn't sound right about the battery
  • tinbender7 and Speedex 24 have said thanks
#4 boyscout862 ONLINE
  • 12,551 Thanks
  • 9,044 posts
Posted March 15, 2015 - 07:21 PM
Welcome to GTT. I agree with the guys above. Put a battery charger on the battery until it is charged. If the battery is low the ignition may not work either.  Good Luck, Rick
#5 glgrumpy OFFLINE
  • 8,564 Thanks
  • 7,881 posts
Posted March 15, 2015 - 08:29 PM
Put on bigger wires/cables than Speedex did for sure. They went Wimpy on them if original. Check for 12 volt or so on battery with no load, and once running should be 13.4 to 14.5 volts with engine charging. That will tell you if you have charge working. Also, re-clean the ground cable and wires at frames/engine.
#6 Speedex 24 OFFLINE
Speedex 24
  • 1 Thanks
  • 5 posts
Posted March 15, 2015 - 08:57 PM
Thanks I will try that. I am getting around 12 volts not running and when its running right under 13. Do you think 285 CCA is big enough or should I get a bigger battery for a 10 HP? It seems like its charging just might not be enough.
#7 boyscout862 ONLINE
  • 12,551 Thanks
  • 9,044 posts
Posted March 15, 2015 - 09:22 PM
That is probably plenty big. I use a 165 CCA on my 3310 with a 10hp B&S. It works fine. What engine do you have? Good Luck, Rick
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 16, 2015 - 09:59 PM
Starter generators don't really break the 14 volt barrier unless they are brand new with the perfect conditions of regulators, wiring, and battery.  From what you describe, yours is where it should be.
I have run 230's on my starter genny equipped tractors, although 350's help it take off a lot faster.  More amperage is good for these systems, although it is not required.
Ben W.
#9 Speedex 24 OFFLINE
Speedex 24
  • 1 Thanks
  • 5 posts
Posted March 17, 2015 - 06:00 PM
When I try to start it the meter reads 4.5 it seems to me it is taking a lot to turn it that's why i thought maybe a bigger battery or starter generator was bad.
#10 Bolens 1000 ONLINE
  • 14,919 Thanks
  • 18,111 posts
Posted March 17, 2015 - 06:14 PM
Ben W.
:ditto:
I was told my a local Delco Remy Dealer that these Starter /Gen combos should never exceed 14 volts or it will wear the starter faster.
Normally you should be getting about 12.5 to about 13.9 when engine is running.
  • superaben said thank you
#11 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 17, 2015 - 10:36 PM
:ditto:
I'm glad you said that, Brian.  I was told the same thing and I didn't believe it.  I guess if you were told that too maybe there is something to the story!
Ben W.
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted March 18, 2015 - 03:10 PM
So I guess my 16 volt battery is out of the question? :poke:
