PEERLESS TRANSAXLE - 2000-006A free-wheel info and images
2 replies to this topic
#1 3v0 OFFLINE
  • 117 Thanks
  • 103 posts
Posted March 15, 2015 - 01:34 PM
2015 03 02 12.42.14 B
This is an intek 18.5 HP hydrostatic tractor with a  PEERLESS TRANSAXLE - 2000-006A and a blown head gasket.  My guess is that after the gasket blew the tractor sat outside and the freewheel lever rusted in.   The rear wheels would not both turn in the same direction.  When pulled it skidded the wheels.
The net talked about the freewheel problem but I did not find any images.
Here is my take on the problem.
The freewheel control rod has a spring (in blue circle)  between it and a lever on the transmission.  The rod will always move but it can just be stretching the spring instead of moving the lever that pivots at the arrow.
You may be able to tell what is going without pulling the seat pan off the tractor.
If your rod sticks out like this when the rod is not hooked (set so the engine should drive the tractor) the lever is stuck in the position for pushing the tractor.  If it not stuck too hard pushing the rod in might move the lever into the 'engine drive' position.
2015 03 15 12.32.40
It should look like this.
2015 03 15 12.32.50
When the lever is stuck in the forward 'engine drive' position it will be more difficult to pull the rod out and hook it.
I soaked it down with penetrating oil overnight and tapped the lever back and forth till it was free.  That took a while so don't give up and keep using the oil
  • MH81, KennyP and boyscout862 have said thanks
  • 29,970 Thanks
Posted March 28, 2015 - 09:40 AM
The GT version of these tractors has a similar setup With a similar issue. Thanks for taking the time to take pics and showing what the issue can be.
  • 3v0 said thank you
#3 AfterShock95 OFFLINE
  • 420 Thanks
  • 365 posts
Posted March 28, 2015 - 09:51 AM
I bought one of these new I still have it . Mine is not a hydro I have used and abused it the original motor 18.5 last for 5 years before the connecting rod broke on the last mow of the year in 2010 I found an old 18 hp L head put it in and still mow grass with it every week
  • MH81 and 3v0 have said thanks
