I am experiencing no engagement of the electric clutch when i engage the cutter knob .Is there a fuse somewhere
no clutch engagement
9 replies to this topic
#1 johny boy OFFLINE
johny boy
  • 4 Thanks
  • 3 posts
Posted March 15, 2015 - 05:00 AM
My zero turn cub cadet was going beautifully and with no apparent reason the cutters stopped  It might be a lack of power to the electric clutch .But where to check it ?
#2 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted March 15, 2015 - 05:27 AM
:wave: Welcome to the forum! Which model zero turn is this? That will help us figure out things, maybe find a wiring diagram for for it.
  • Gabriel said thank you
#3 boyscout862 OFFLINE
  • 13,688 Thanks
  • 9,474 posts
Posted March 15, 2015 - 05:36 AM
Welcome to GTT. Try a simple test light to see if electricity is getting to the clutch. Good Luck, Rick
  • Gabriel and johny boy have said thanks
#4 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted March 15, 2015 - 06:13 AM
Welcome! There could be a bad connection somewhere in the clutch circuit which often includes safety switches. Without knowing anything about the tractor I would start with a good visual inspection looking for the fuse panel to check the fuses as well as damaged, burnt or disconnected wires. Good luck with the repair.
#5 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted March 15, 2015 - 06:19 AM
Welcome to GTtalk! with your engine off, disconnect the
plug (between clutch and wire harness, ) you may have to have a helper sitting on seat because of seat switch.
test light between chassie ground and your harness... should light. would be very helpful to know the model.
#6 MH81 OFFLINE
  • 29,979 Thanks
Posted March 15, 2015 - 06:35 AM
:ditto: on all above with one addendum.
You will need to check for both power and a good ground.
Many of those clutches have a ground connection only thru the harness, a loss of either hot or ground will give you the same symptom in this situation.
  • tractorgarden said thank you
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,818 Thanks
  • 4,308 posts
Posted March 15, 2015 - 12:23 PM
:welcometogttalk:
#8 johny boy OFFLINE
johny boy
  • 4 Thanks
  • 3 posts
Posted March 15, 2015 - 06:47 PM
Thanks guys .sorry not supplying model number .Its 17AF9BKH756 DOM2007.I have now tested the ohms on the clutch and that reads  about 3.5  so its not the clutch .Next step trace back power to switch etc
#9 Gabriel OFFLINE
Gabriel
  • 1,449 Thanks
  • 1,863 posts
Posted March 18, 2015 - 08:13 AM
Welcome to GTTalk!
#10 johny boy OFFLINE
johny boy
  • 4 Thanks
  • 3 posts
Posted March 18, 2015 - 06:37 PM
thanks for the advice people  i tested the ohms  [3.5] of clutch  its ok .then went back along wires to first connector .found one side of connection had pulled out of plastic housing just enogh to not make contact.  easily fixed
  • olcowhand, KennyP, tractorgarden and 1 other said thanks
