Simplicity 725 low speed belt pulley
19 replies to this topic
#16 drbish ONLINE
drbish
    Collecter
  • 1,278 Thanks
  • 1,209 posts
Posted March 15, 2015 - 02:38 PM
It has been so many years since I put one on it that I can't remember but I do remember that the last time I changed it I went to a belt and rubber place with the old belt and got one the same size. It is due for a belt this spring and I will do the same again. Take a thin roper or something similar and run it around the pulley's and measure the length. It's a 5/8 belt as I recall.
Central Indiana Rubber?
  • rustyoldjunk said thank you
#17 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,435 Thanks
  • 1,244 posts
Posted March 15, 2015 - 02:40 PM
That is the place.
#18 Cjet69 OFFLINE
Cjet69
  • 282 Thanks
  • 175 posts
Posted March 15, 2015 - 06:58 PM
This is my old belt. I don't know if some of it is missing or not.
#19 Cjet69 OFFLINE
Cjet69
  • 282 Thanks
  • 175 posts
Posted March 16, 2015 - 08:55 PM
I did some searching and found some info on the speed reduction kit #238. It looks like it has a 10" pulley and uses the 49" belt. My 8" pulley I would guess would use a belt in the 44"-46" range. In the link Scroll down to the bottom you will see the Speed Reduction kit info.
http://simpletractor...o_backaches.htm
#20 Cjet69 OFFLINE
Cjet69
  • 282 Thanks
  • 175 posts
Posted May 29, 2015 - 11:25 AM
Finally got back to my belt issue and found one the correct size. Its 5/8" x 45".
  • Simpleton said thank you
