Simplicity 725 low speed belt pulley
19 replies to this topic
#1 Cjet69 ONLINE
Cjet69
  • 542 Thanks
  • 303 posts
Posted March 14, 2015 - 04:08 PM
I just picked up a freebie Simplicity 725. I bought a drive belt and it didn't fit. It was to short. So after a few choice words I looked at the parts book again and noticed that these had a Low Speed Belt & Pulley Kit. I'm thinking this is what I must have on this tractor since it had a tiller on it at one time. The pulley measures 8" dia. Would this be the low speed pulley?
  • rustyoldjunk said thank you
#2 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted March 14, 2015 - 04:11 PM
Did you buy a belt using the original manufactures part number? If you have a Part # I can cross reference it for you to see if it was the belt or the pulleys being the problem.
#3 Cjet69 ONLINE
Cjet69
  • 542 Thanks
  • 303 posts
Posted March 14, 2015 - 04:28 PM
Yes for a standard belt. The number I had was 154273 and the low speed kit uses belt # 155004 according to the PDF manual I have, but I am not sure it is correct. Any info would be appreciated. Thanks, Cjet69
#4 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted March 14, 2015 - 04:49 PM
154273 is spec to 42''
155004 is spec to 49''
  • Cjet69 said thank you
#5 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted March 14, 2015 - 06:06 PM
They offered a 8" and a 10" pulley
#6 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted March 14, 2015 - 07:00 PM
I knew they offered a high and low . But I had no idea you could have got 8 or 10 " pulley
Edited by AfterShock95, March 14, 2015 - 07:04 PM.
#7 Cjet69 ONLINE
Cjet69
  • 542 Thanks
  • 303 posts
Posted March 14, 2015 - 07:44 PM
So was the 8" the standard size and the 10" the low speed?
#8 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted March 14, 2015 - 07:51 PM
6" was standard
#9 Cjet69 ONLINE
Cjet69
  • 542 Thanks
  • 303 posts
Posted March 14, 2015 - 08:08 PM
6" was standard
Thanks, Killer_A-C.  Do you happen to know what belt size or number would go with the 8" pulley?
#10 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted March 14, 2015 - 08:13 PM
Sorry not right off I dont
#11 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted March 14, 2015 - 10:16 PM
Killer nailed it. The 6 inch was standard,I have that one on a B1. The 8 inch was a low speed,I have that one one my 700. I would like to grab a 10 inch lower speed one day just for kicks.
#12 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted March 15, 2015 - 05:57 AM
#13 Cjet69 ONLINE
Cjet69
  • 542 Thanks
  • 303 posts
Posted March 15, 2015 - 11:54 AM
What size belt does your 700 with the 8" pulley take?
#14 Cjet69 ONLINE
Cjet69
  • 542 Thanks
  • 303 posts
Posted March 15, 2015 - 11:55 AM
Thanks, drbish. Good reference material.
  • drbish said thank you
#15 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted March 15, 2015 - 01:55 PM
It has been so many years since I put one on it that I can't remember but I do remember that the last time I changed it I went to a belt and rubber place with the old belt and got one the same size. It is due for a belt this spring and I will do the same again. Take a thin roper or something similar and run it around the pulley's and measure the length. It's a 5/8 belt as I recall.
