Power King 16/18 trans parts
for free tranmission parts
7 replies to this topic
#1 abu507 OFFLINE
abu507
  • 11 Thanks
  • 37 posts
Posted March 13, 2015 - 11:39 AM
I need a few parts for transmission this is a 1989 serial 65827 . New here but just tore it down got tractor about 2 weeks ago was stuck in first gear. I need the shifting fork s for sure maybe whole trans for parts. I also see the plate held on the front of transmission is snap ring held is bad it has the pins that stick out. Any help would be great junk yards etc.
Thank You Dan Bailey
#2 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted March 13, 2015 - 01:00 PM
Welcome to GTT.  Someone may be along to help with the parts. Check out our Manuals Section for 3 free downloads per day. Good Luck, Rick
  • abu507 said thank you
#3 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted March 13, 2015 - 02:29 PM
Hi,
I assume by the '89 model year, you have a 4 sp.
For new parts, you can contact: Mission Mfg in Princeton, In as they have a good selection of new parts for these tractors.
Otherwise, ebay.
The "plastic" pk's did not sell very well and are not plentiful.
Good luck.
Chuck
  • Alc and abu507 have said thanks
#4 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted March 13, 2015 - 11:00 PM
There is another posting on here in the Power King section with drawings, photos and ideas, might wanna check it out! Usually the clutch that goes bad on these, or comnination of both, might wanna make sure trans didn't have bad bearing and front seal and leak into the clutch.
#5 Alc ONLINE
  • 6,902 Thanks
  • 7,468 posts
Posted March 14, 2015 - 07:04 AM
Welcome to GTTalk ! If you have a 4 speed I won't be much help
#6 bob0usa OFFLINE
bob0usa
  • 20 Thanks
  • 27 posts
Posted March 14, 2015 - 07:29 AM
yours was built just after mine ,,    serial "65823"  if your having clutch problems, i've got most of that figured out! I've got diagrams if you need them,,  also there are other folks that will be uploading on here also,,,
#7 abu507 OFFLINE
abu507
  • 11 Thanks
  • 37 posts
Posted March 19, 2015 - 12:39 PM
Still looking for 4 spd transmission all the fiberglass fender models fit I guess. Can some one send me salvage yards in there are for lawn and garden to check
#8 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted March 20, 2015 - 11:46 PM
the trans on a 1200 series, the smaller version is almost the same, but rear case is diff, as it goes on a diff rear-end. Most of internals are same, cept maybe the output shaft? Not sure on the shaft.  Think maybe the shift lever is diff length or bent diff also. Might check on that.  What problems you having with trans?  I used to have a few in parts, but have since sold them as am getting out of the hobby and was done with my Plastic Kings.  Watch epay and go to swap meets.
Also tagged with one or more of these keywords: for free, tranmission parts
